Dizzy49 99 Posted June 22, 2017 Posted June 22, 2017 I turned Hardware Acceleration off, and set Max Bitrate to 5.0, and Audio to Downmix to Stereo. Previously these two files would play to a point and then stop and kick you out to the Emby file screen. On both files we are hitting "Resume from XX:XX" The first one still does the same thing. It spins, and looks like it's trying to play, then kicks you out. On the server it says it's transcoding at 5.0mbps. The second one was odd. It was at the grey screen with the circle trying to load. It took nearly a full minute, and then it finally played. On the server, it was showing that it played 1-2 seconds, then would jump back to where it started. It did this for a while, until it finally played. I have attached server logs and transcode logs. I also sent logs from the Fire Stick at 3:40pm Mountain Time ffmpeg-transcode-5f10b462-9304-4bbf-8657-8b9953096119.txt ffmpeg-transcode-158df17d-7974-476a-a09a-4127faad9976.txt ffmpeg-transcode-c8b6ac48-8a25-42ef-81e8-2b9a040a39c9.txt server-63633686399.txt
Luke 42244 Posted June 24, 2017 Posted June 24, 2017 @@Dizzy49, what was the name of the Emby user that you submitted logs from? @@ebr will need that in order to review. Thanks !
ebr 16337 Posted June 24, 2017 Posted June 24, 2017 In the case of Schindler's List, whatever the item is being transcoded to cannot be read by the player. I/System.out(31899): internalError [11.02, loadError] E/ExoPlayerImplInternal(31899): Source error. E/ExoPlayerImplInternal(31899): com.google.android.exoplayer2.source.UnrecognizedInputFormatException: None of the available extractors (MatroskaExtractor, FragmentedMp4Extractor, Mp4Extractor, Mp3Extractor, AdtsExtractor, Ac3Extractor, TsExtractor, FlvExtractor, OggExtractor, PsExtractor, WavExtractor) could read the stream.
Luke 42244 Posted June 26, 2017 Posted June 26, 2017 @@Dizzy49 we are looking into this, thanks for the report.
ebr 16337 Posted July 3, 2017 Posted July 3, 2017 @@Dizzy49 please re-try this with the latest beta of the Android TV app (1.4.21+) as the internal player has been updated. Thanks.
Dizzy49 99 Posted July 21, 2017 Author Posted July 21, 2017 Odd, I didn't get notice the last time you replied. How can I download the Beta on a Fire Stick? I will be going back to my father's in two weeks, I will update and perform testing while I am there.
Luke 42244 Posted July 21, 2017 Posted July 21, 2017 https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/
Dizzy49 99 Posted July 22, 2017 Author Posted July 22, 2017 I enabled all Communications in Amazon, please send beta invite.
ebr 16337 Posted July 22, 2017 Posted July 22, 2017 I enabled all Communications in Amazon, please send beta invite. Please PM me the email address associated with the Amazon account. Thanks.
