KRA 39 Posted February 19, 2014 Posted February 19, 2014 Suggestion to add an option to set default client for playback when you push play on web gui. You already have the remote option to start playback on another device/client rather than web, but rather than having to click remote, choose the client and then press play, I suggest the option to choose the default client for play button.
Beardyname 199 Posted February 19, 2014 Posted February 19, 2014 This is actually a cool idea, but could be trouble some if the device you choose is one that is frequently turned on/off or even hibernating. still +1 from me.
ebr 16354 Posted February 19, 2014 Posted February 19, 2014 There is no way to know what devices will be available. The remote control functions are based on sessions which are created and destroyed with each client connection.
KRA 39 Posted February 20, 2014 Author Posted February 20, 2014 I see the problem where this is session based, but I don't give up I have no programming skills so I may be way off here. But I notice clients have ID/Name, wouldn't it be possible to find client based on name rather than session, if said client is not available/connected it would fall back to web playback or next on priority list ?
