theBrad 0 Posted June 21, 2017 Posted June 21, 2017 Hey - apologies if this comes across as a noob post or whatever, I've recently been introduced to Emby and I am absolutely amazed with it, it's absolutely fantastic, so good that I've decided to host my own Emby server. I'm looking at spending anywhere from £300-500 (although this can be pushed up slightly if need be) for my build. I've considered these things currently: Mac Mini (16GB Ram, i5 Processor, 240GB SSD) HPe Proliant ML10 Gen9 HPE ProLiant Gen8 G1610T 819185-421 (4GB RAM) MicroServer Storage won't be a problem as I'll have a 8TB NAS to start with. My requirements so far are: Steam to 3 devices in the same household. (Will most likely be 3 at the max, but maybe potential for 4-5) Be able to stream remotely to 1-2 people (If I'm at my girlfriends house or travelling for work) Do either of the 3 I've posted look like they could do what I require? Or do any of you kind folk know a better build that will give me more bang for my buck? I'm not opposed to building the server myself out of parts, just trying to get some knowledge here. Many thanks
theBrad 0 Posted June 21, 2017 Author Posted June 21, 2017 what processor in the ML10? Intel Xeon E3-1225V5 / 3.3GHz (Quad-Core)
pir8radio 1313 Posted June 21, 2017 Posted June 21, 2017 Intel Xeon E3-1225V5 / 3.3GHz (Quad-Core) I'm an HP fan, I don't think you will like the micro server after a while, its kind of restricted as to what hardware you can add/remove. I say go with the ML10. 1
theBrad 0 Posted June 21, 2017 Author Posted June 21, 2017 I'm an HP fan, I don't think you will like the micro server after a while, its kind of restricted as to what hardware you can add/remove. I say go with the ML10. Do you think the ML10 is powerful enough to stream / transcode to one remote location?
Swynol 375 Posted June 21, 2017 Posted June 21, 2017 (edited) my i3 can handle 2-3 full transcoded streams fairly easy. Quadcore should have no issues with 5+ streams that you need. i usually transcode internally, however i sometimes stream to 2 remote locations at once. it will be more limited to your upload connection, in my case its 20Mbps. are you looking for rack mount or prefer to stick with tower? A HP DL380 which has 2x xeon CPUs can be had for similar price to the ML10. just need to make sure it has 3.5" drives and not 2.5" Edited June 21, 2017 by Swynol
theBrad 0 Posted June 21, 2017 Author Posted June 21, 2017 my i3 can handle 2-3 full transcoded streams fairly easy. Quadcore should have no issues with 5+ streams that you need. i usually transcode internally, however i sometimes stream to 2 remote locations at once. it will be more limited to your upload connection, in my case its 20Mbps. are you looking for rack mount or prefer to stick with tower? A HP DL380 which has 2x xeon CPUs can be had for similar price to the ML10. just need to make sure it has 3.5" drives and not 2.5" Preferably a tower for now.
mastrmind11 722 Posted June 21, 2017 Posted June 21, 2017 Intel Xeon E3-1225V5 / 3.3GHz (Quad-Core) According to http://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+E3-1225+v5+%40+3.30GHz, you can get about 7 concurrent transcodes out of that CPU.
theBrad 0 Posted June 21, 2017 Author Posted June 21, 2017 According to http://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+E3-1225+v5+%40+3.30GHz, you can get about 7 concurrent transcodes out of that CPU. Perfect! Thank you very much, think I'll be going with the ML10 then! Thank you guys so much.
dcrdev 255 Posted June 22, 2017 Posted June 22, 2017 (edited) Unless you are getting some kind of cashback from the HP one - might i suggest you go with the Lenovo ThinkServer TS150. It has the same specs - only unlike the ML10 it has an HDMI port and better cooling performance; it's also roughly the same price. With the ML10 you don't get vga or hdmi, you only get 2 displayports neither of which support HDMI output, so if you don't have a displayport monitor - the initial set up is going to require you to purchase an active displayport-to-hdmi converter; which cost significantly more than a passive one. Edited June 22, 2017 by dcrdev
theBrad 0 Posted June 22, 2017 Author Posted June 22, 2017 Unless you are getting some kind of cashback from the HP one - might i suggest you go with the Lenovo ThinkServer TS150. It has the same specs - only unlike the ML10 it has an HDMI port and better cooling performance; it's also roughly the same price. With the ML10 you don't get vga or hdmi, you only get 2 displayports neither of which support HDMI output, so if you don't have a displayport monitor - the initial set up is going to require you to purchase an active displayport-to-hdmi converter; which cost significantly more than a passive one. Hi, I can get the ThinkServer TS150 for about £80-100 cheaper than the ML10, but the processor on the ThinkServer doesn't look as good as the ML10's to me.. Reckon it'll be okay for 5-6 streams?
dcrdev 255 Posted June 22, 2017 Posted June 22, 2017 I'm not sure which processor you are referring to, but I meant go for the option with the E3-1225V5 i.e. the same as the ml10.
pir8radio 1313 Posted June 22, 2017 Posted June 22, 2017 Keep in mind the IBM/Lenovo also uses display port and will require an adapter (passive) as well, however the active adapters for the HP are only $8.00 US. They have the same specs otherwise, it's just what you like. All hardware has fans and haters. I personally have used HP for over a decade, so I'm a bit biased. I also like the physical design of The more recent HP's they look cool.
mastrmind11 722 Posted June 22, 2017 Posted June 22, 2017 I have a Dell PowerEdge w/ an E3 1225v3, basically the same CPU as the HP. Can be had for under $400 + 16GB of RAM for about $100. Thing's a beast.
dcrdev 255 Posted June 22, 2017 Posted June 22, 2017 Keep in mind the IBM/Lenovo also uses display port and will require an adapter (passive) as well, however the active adapters for the HP are only $8.00 US. They have the same specs otherwise, it's just what you like. All hardware has fans and haters. I personally have used HP for over a decade, so I'm a bit biased. I also like the physical design of The more recent HP's they look cool. Yeah but the TS150 has 1 DP + 1 HDMI. In regards to fans I'm just saying that the HP has one exhaust and one CPU fan - there is very little airflow around the drive cage, I'm really not hating on the premise of fans. The Lenovo has an additional fan under the drive cage - that's where I see the benefit especially since the fan headers on both boards are likely proprietary. Both are really great options - but to me the Lenovo edges slightly ahead ; which is also why I'm buying one myself.
theBrad 0 Posted June 22, 2017 Author Posted June 22, 2017 I have a Dell PowerEdge w/ an E3 1225v3, basically the same CPU as the HP. Can be had for under $400 + 16GB of RAM for about $100. Thing's a beast. Wow that looks fantastic! I could get that for just £230 (not including the 16GB of RAM) Definitely tempting, does it have HDMI or will I need an adaptor for this too?
mastrmind11 722 Posted June 22, 2017 Posted June 22, 2017 Wow that looks fantastic! I could get that for just £230 (not including the 16GB of RAM) Definitely tempting, does it have HDMI or will I need an adaptor for this too? 2x display ports so you'll need an adapter. However, keep in mind that if you're planning to use it as an HTPC instead of just a server, you'll need to look elsewhere as Dell did not implement audio-out via DP in the bios. Also note these boxes don't come w/ an OS, so you'll need to bring your own (I run ubuntu server). 1
theBrad 0 Posted June 22, 2017 Author Posted June 22, 2017 2x display ports so you'll need an adapter. However, keep in mind that if you're planning to use it as an HTPC instead of just a server, you'll need to look elsewhere as Dell did not implement audio-out via DP in the bios. Also note these boxes don't come w/ an OS, so you'll need to bring your own (I run ubuntu server). Cool, I don't plan to use this as anything other than a server that hosts my Emby media, all the streaming I need will be done via Chromecast and Fire Sticks
mastrmind11 722 Posted June 22, 2017 Posted June 22, 2017 Cool, I don't plan to use this as anything other than a server that hosts my Emby media, all the streaming I need will be done via Chromecast and Fire Sticks Cool. If you do plan to buy one, make sure to double check the processor, it comes in 2 flavors so make sure you get the Xeon version.
theBrad 0 Posted June 22, 2017 Author Posted June 22, 2017 Cool. If you do plan to buy one, make sure to double check the processor, it comes in 2 flavors so make sure you get the Xeon version. That's the one I've got bookmarked! Looks fantastic, any idea how many streams roughly I could get out of it?
mastrmind11 722 Posted June 22, 2017 Posted June 22, 2017 That's the one I've got bookmarked! Looks fantastic, any idea how many streams roughly I could get out of it? Its basically the same cpu as the one in the HP that I linked above, so about 7.
