himisk71 4 Posted June 21, 2017 Posted June 21, 2017 Hi there. I am missing the EPG for 1 channel (AXN HD) in my Emby. See attached Screenshot. EPG is available in tvheadend itself, in Kodi and in tvhclient (Android) too. So, what can i do to get this channel EPG? Also attached the server-log after a channel refresh Log.txt
Luke 42243 Posted June 21, 2017 Posted June 21, 2017 What source of guide data are you using, xmltv or schedules direct?
himisk71 4 Posted June 21, 2017 Author Posted June 21, 2017 source is the over-the-air epg from a tvheadend server in an unraid docker.
himisk71 4 Posted June 22, 2017 Author Posted June 22, 2017 anything i can do further to solve this issue?
Luke 42243 Posted June 24, 2017 Posted June 24, 2017 @@Tolotos, I see the tvheadend plugin prints out a huge amount of logging during the guide refresh process. are you able to use that to get an idea of whether or not the plugin requested the programs for the channel? Thanks !
Tolotos 61 Posted June 25, 2017 Posted June 25, 2017 This are the lines in the log: 2017-06-21 07:18:49.8571 Info App: [TVHclient] ChannelDataHelper: Adding channel HTSMessage: <dump> channelId : 1848312008 channelNumber : 46 channelName : AXN HD channelIcon : imagecache/2109979103 eventId : 716712 nextEventId : 716714 services : HTSMessage: <dump> name : kdsky/346MHz/AXN HD type : HDTV content : 1 caid : 65535 caname : Encrypted service </dump> , tags : 4, 2, method : channelAdd </dump> 2017-06-21 07:21:15.9911 Info App: [TVHclient] GetProgramsAsync, ask TVH for events of channel '1848312008'. 2017-06-21 07:21:15.9911 Info App: [TVHclient] GetEventsResponseHandler.handleResponse: received answer from TVH server HTSMessage: <dump> error : Channel does not exist seq : 115 </dump> This must be an internal TVHeadend error.
himisk71 4 Posted June 25, 2017 Author Posted June 25, 2017 This must be an internal TVHeadend error. ok, i did delete the channel in tvheadend and remap the channel on number 48. now i have a working epg for the channel, but the "old" axn hd is still alive on channelnumber 46. see screenshot. restarting emby did not help.
Luke 42243 Posted June 25, 2017 Posted June 25, 2017 Thanks @@Tolotos ! @@himisk71, please take a look at this, thanks !
himisk71 4 Posted June 26, 2017 Author Posted June 26, 2017 Ok, now the "old" channel is gone and everything is fine. thx for your attention and keep up your good work!
