skivy71 5 Posted June 20, 2017 Posted June 20, 2017 Hi, I've added channel logo's to my m3u playlist and as far as I can tell, they're working fine. However, the problem I've seen is that with my Schedules Direct account linked, emby still wants to use the SD logo's instead... and they are just wrong. Not sure if I can ammend my SD account for no logo's, but can emby choose not to use them if the m3u provides them instead? Also, I've since deleted my SD source within emby (which has dropped my EPG data as expected), but emby must be caching these logo's some how as they are still being used over mine :-/ I've located the /var/lib/emby-server/cache folder, but unsure what to purge. Thanks Neil
Luke 42243 Posted June 23, 2017 Posted June 23, 2017 hi @@skivy71, we would have to add settings to allow you to designate a preference of where the logos should come from. Right now you would just have to use the editor features to set the logos manually.
skivy71 5 Posted June 25, 2017 Author Posted June 25, 2017 Hi Luke, Could you point me to the editor features? Thanks Neil
Luke 42243 Posted June 25, 2017 Posted June 25, 2017 Can you tell us what prevented you from discovering that on your own?
skivy71 5 Posted June 25, 2017 Author Posted June 25, 2017 I did find it on my own, just prior to your reply... but not sure if its where said... I did if via the metadata manager of the emby server web portal.
