bluemonkey07 590 Posted June 19, 2017 Posted June 19, 2017 After updating to 3.2.20 my recordings library no long as a dynamic tile generate. After updating is disappeared so I have waited a week in the hopes that a new one would be generated but it is still blank/default
bluemonkey07 590 Posted June 20, 2017 Author Posted June 20, 2017 Seems OK here. what image does it have now?
Luke 42238 Posted June 21, 2017 Posted June 21, 2017 What kind of media do you have in your recordings library?
bluemonkey07 590 Posted June 21, 2017 Author Posted June 21, 2017 (edited) Recorded movie and tvshows subfolders created from the built-in live tv settings Edited June 21, 2017 by Vidman
Luke 42238 Posted June 24, 2017 Posted June 24, 2017 @@Vidman, on the web app home screen, can you right click the library -> refresh, then check the box to replace existing images. then grab the server log. I want to see if there's an image processing failure of some sort. Thanks !
bluemonkey07 590 Posted June 25, 2017 Author Posted June 25, 2017 Log.txt @@Vidman, on the web app home screen, can you right click the library -> refresh, then check the box to replace existing images. then grab the server log. I want to see if there's an image processing failure of some sort. Thanks ! restarted server and click refresh all images at 13:08 Log.txt
Luke 42238 Posted June 25, 2017 Posted June 25, 2017 @@Vidman, you're using the docker server? this should be resolved for the next release, thanks.
Luke 42238 Posted June 25, 2017 Posted June 25, 2017 Ok, it should still be resolved for the next release anyway, thanks.
