JeremyFr79 228 Posted February 19, 2014 Posted February 19, 2014 All Clients are running MBC Ver. 3.0.129.0 2-12.2, Server is on Ver. 3.0.5161.29813. I've looked at the logs and don't see anything in relation to Intro's It's all been working fine but recently in the last week stopped working on all my clients running MBC, however it works properly in MBT, quite stumped.
ebr 16343 Posted February 19, 2014 Posted February 19, 2014 May I please see an MBC log when you play something that should have an intro?
JeremyFr79 228 Posted February 19, 2014 Author Posted February 19, 2014 Ok, so it get's weirder, Intro's seems to be working fine with most movies on my server, however doesn't seem to initiate with movies that have been added recently.
JeremyFr79 228 Posted February 19, 2014 Author Posted February 19, 2014 2014-02-19 10:46:51.7812,Debug,,Attempting to wake server at address 00-30-48-D8-CE-DD,1,Application 2014-02-19 10:46:51.7852,Debug,,Wake command sent,1,Application 2014-02-19 10:46:51.8232,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\strings-en.xml,1,Application 2014-02-19 10:46:51.8372,Debug,,=========System looking for assembly: Newtonsoft.Json,, Version=4.5.0.0,, Culture=neutral,, PublicKeyToken=30ad4fe6b2a6aeed,1,Application 2014-02-19 10:46:51.8372,Info,,Resolving Newtonsoft.Json,, Version=4.5.0.0,, Culture=neutral,, PublicKeyToken=30ad4fe6b2a6aeed to C:\ProgramData\MediaBrowser-Classic\Newtonsoft.Json.dll,1,Application 2014-02-19 10:46:51.8872,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/System/Info?format=Json,1,Application 2014-02-19 10:46:52.5547,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/System/Configuration?format=Json,1,Application 2014-02-19 10:46:52.6298,Info,,====== Connected to server 192.168.1.7:8096,1,Application 2014-02-19 10:46:52.6328,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/Public?isDisabled=False&format=Json,1,Application 2014-02-19 10:46:52.7436,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application 2014-02-19 10:46:52.7446,Info,,System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application 2014-02-19 10:46:52.7536,Info,,==========Using new SQL Repo========,1,Application 2014-02-19 10:46:53.1016,Info,,Playstate initialization took 0.01 seconds.,1,Application 2014-02-19 10:46:53.1216,Info,,Total Kernel Init took 1.35 seconds.,1,Application 2014-02-19 10:46:53.1556,Info,,Successfully loaded fastload data for : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,16,Worker thread for Fast Load Loader 2014-02-19 10:46:53.2456,Info,,Information DisplayText: Welcome to Media Browser,1,Application 2014-02-19 10:46:53.2817,Info,,Finished validating : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,16,Worker thread for Fast Load Loader 2014-02-19 10:46:53.2817,Info,,Dictionary loading and validation took 0.18 seconds.,16,Worker thread for Fast Load Loader 2014-02-19 10:46:53.2887,Info,,Media Browser (version 3.0.129.0 2-12.2) Starting up.,1,Application 2014-02-19 10:46:53.2887,Info,,Startup parameters: ,1,Application 2014-02-19 10:46:53.2887,Info,,Server version: 3.0.5163.756,1,Application 2014-02-19 10:46:53.5058,Debug,,=========System looking for assembly: MediaBrowser.resources,, Version=3.0.129.0,, Culture=en-US,, PublicKeyToken=59fc04479785fd64,1,Application 2014-02-19 10:46:53.5068,Debug,,=========System looking for assembly: MediaBrowser.resources,, Version=3.0.129.0,, Culture=en-US,, PublicKeyToken=59fc04479785fd64,1,Application 2014-02-19 10:46:53.5368,Debug,,=========System looking for assembly: MediaBrowser.resources,, Version=3.0.129.0,, Culture=en-US,, PublicKeyToken=59fc04479785fd64,1,Application 2014-02-19 10:46:53.5368,Debug,,=========System looking for assembly: MediaBrowser.resources,, Version=3.0.129.0,, Culture=en-US,, PublicKeyToken=59fc04479785fd64,1,Application 2014-02-19 10:46:53.8046,Debug,,Sending Http Post to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Authenticate?format=Json,1,Application 2014-02-19 10:46:54.1736,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items/Root?format=Json,1,Application 2014-02-19 10:46:54.4838,Debug,,Added Plugin assembly: BDScreenSaver,, Version=2.0.0.3,, Culture=neutral,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:54.5078,Debug,,Added Plugin assembly: Chocolate,, Version=3.0.4.1,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.5427,Debug,,=========System looking for assembly: MediaBrowser,, Version=2.6.1.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application 2014-02-19 10:46:54.5427,Info,,Plug-in reference to MediaBrowser,, Version=2.6.1.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.129.0,1,Application 2014-02-19 10:46:54.5461,Debug,,Added Plugin assembly: Destiny,, Version=4.0.0.0,, Culture=neutral,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.5745,Debug,,=========System looking for assembly: MediaBrowser,, Version=2.5.2.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application 2014-02-19 10:46:54.5745,Info,,Plug-in reference to MediaBrowser,, Version=2.5.2.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.129.0,1,Application 2014-02-19 10:46:54.5765,Debug,,Added Plugin assembly: Diamond,, Version=0.3.6.4,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.6035,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.106.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application 2014-02-19 10:46:54.6035,Info,,Plug-in reference to MediaBrowser,, Version=3.0.106.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.129.0,1,Application 2014-02-19 10:46:54.6105,Info,,Subdued - Creating Theme,1,Application 2014-02-19 10:46:54.6235,Debug,,=========System looking for assembly: Subdued.resources,, Version=3.0.1.13,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.6255,Debug,,=========System looking for assembly: Subdued.resources,, Version=3.0.1.13,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.6255,Debug,,=========System looking for assembly: Subdued.resources,, Version=3.0.1.13,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.6265,Debug,,=========System looking for assembly: Subdued.resources,, Version=3.0.1.13,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.6325,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application 2014-02-19 10:46:54.6365,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application 2014-02-19 10:46:54.6365,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application 2014-02-19 10:46:54.6395,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application 2014-02-19 10:46:54.6405,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application 2014-02-19 10:46:54.6435,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application 2014-02-19 10:46:54.6435,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application 2014-02-19 10:46:54.6475,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application 2014-02-19 10:46:54.6475,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application 2014-02-19 10:46:54.6515,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application 2014-02-19 10:46:54.6515,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application 2014-02-19 10:46:54.6545,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application 2014-02-19 10:46:54.6555,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application 2014-02-19 10:46:54.6585,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application 2014-02-19 10:46:54.6585,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application 2014-02-19 10:46:54.6625,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application 2014-02-19 10:46:54.6625,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application 2014-02-19 10:46:54.6665,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application 2014-02-19 10:46:54.6665,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application 2014-02-19 10:46:54.6705,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application 2014-02-19 10:46:54.6705,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application 2014-02-19 10:46:54.6735,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application 2014-02-19 10:46:54.6745,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application 2014-02-19 10:46:54.6775,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application 2014-02-19 10:46:54.6785,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application 2014-02-19 10:46:54.6815,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application 2014-02-19 10:46:54.6815,Info,,Subdued - Validating installed styles,1,Application 2014-02-19 10:46:54.6815,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application 2014-02-19 10:46:54.6815,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application 2014-02-19 10:46:54.6815,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application 2014-02-19 10:46:54.6815,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application 2014-02-19 10:46:54.6825,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application 2014-02-19 10:46:54.6945,Info,,Subdued - Theme Creation took 0.08 seconds.,1,Application 2014-02-19 10:46:54.6955,Debug,,Added Plugin assembly: Subdued,, Version=3.0.1.13,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.7276,Debug,,Added Plugin assembly: Vanilla,, Version=4.0.0.0,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.7296,Info,,BDScreenSaver (version 2.0.0.3) Plug-in Loaded.,1,Application 2014-02-19 10:46:54.7646,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Chocolate-strings-en.xml,1,Application 2014-02-19 10:46:54.7836,Debug,,=========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.7846,Debug,,=========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.7846,Debug,,=========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.7846,Debug,,=========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.8046,Info,,Chocolate Theme (version 3.0.4.1) Loaded.,1,Application 2014-02-19 10:46:54.8106,Info,,Destiny (version 4.0.0.0) Theme Loaded.,1,Application 2014-02-19 10:46:54.8376,Debug,,=========System looking for assembly: Destiny.resources,, Version=4.0.0.0,, Culture=en-US,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.8386,Debug,,Destiny =========System looking for assembly: Destiny.resources,, Version=4.0.0.0,, Culture=en-US,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.8386,Debug,,=========System looking for assembly: Destiny.resources,, Version=4.0.0.0,, Culture=en-US,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.8386,Debug,,Destiny =========System looking for assembly: Destiny.resources,, Version=4.0.0.0,, Culture=en-US,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.8396,Debug,,=========System looking for assembly: Destiny.resources,, Version=4.0.0.0,, Culture=en,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.8396,Debug,,Destiny =========System looking for assembly: Destiny.resources,, Version=4.0.0.0,, Culture=en,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.8396,Debug,,=========System looking for assembly: Destiny.resources,, Version=4.0.0.0,, Culture=en,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.8396,Debug,,Destiny =========System looking for assembly: Destiny.resources,, Version=4.0.0.0,, Culture=en,, PublicKeyToken=null,1,Application 2014-02-19 10:46:54.8796,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.74.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application 2014-02-19 10:46:54.8796,Info,,System.Data.SQLite,, Version=1.0.74.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application 2014-02-19 10:46:54.9016,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Destiny-strings-en.xml,1,Application 2014-02-19 10:46:54.9177,Info,,Destiny (version 4.0.0.0) Theme Loaded.,1,Application 2014-02-19 10:46:54.9267,Info,,Diamond Theme Loaded.,1,Application 2014-02-19 10:46:54.9347,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Diamond-strings-en.xml,1,Application 2014-02-19 10:46:54.9397,Debug,,=========System looking for assembly: Diamond.resources,, Version=0.3.6.4,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.9397,Debug,,Destiny =========System looking for assembly: Diamond.resources,, Version=0.3.6.4,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.9407,Debug,,=========System looking for assembly: Diamond.resources,, Version=0.3.6.4,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.9407,Debug,,Destiny =========System looking for assembly: Diamond.resources,, Version=0.3.6.4,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.9417,Debug,,=========System looking for assembly: Diamond.resources,, Version=0.3.6.4,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.9417,Debug,,Destiny =========System looking for assembly: Diamond.resources,, Version=0.3.6.4,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.9417,Debug,,=========System looking for assembly: Diamond.resources,, Version=0.3.6.4,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.9417,Debug,,Destiny =========System looking for assembly: Diamond.resources,, Version=0.3.6.4,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:54.9537,Info,,Subdued - Initializing Theme,1,Application 2014-02-19 10:46:54.9557,Info,,Subdued - Checking active style: C:\ProgramData\MediaBrowser-Classic\Subdued_Styles.mcml,1,Application 2014-02-19 10:46:54.9577,Info,,Subdued - Setting active style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application 2014-02-19 10:46:54.9901,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Subdued-strings-en.xml,1,Application 2014-02-19 10:46:54.9901,Info,,Subdued - Theme Initialization took 0.04 seconds.,1,Application 2014-02-19 10:46:54.9901,Info,,Subdued - Version 3.0.1.13 ready,1,Application 2014-02-19 10:46:55.0010,Info,,Vanilla (version 4.0.0.0) Initializing.,1,Application 2014-02-19 10:46:55.0221,Debug,,=========System looking for assembly: Vanilla.resources,, Version=4.0.0.0,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.0221,Debug,,Destiny =========System looking for assembly: Vanilla.resources,, Version=4.0.0.0,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.0221,Debug,,=========System looking for assembly: Vanilla.resources,, Version=4.0.0.0,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.0221,Debug,,Destiny =========System looking for assembly: Vanilla.resources,, Version=4.0.0.0,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.0231,Debug,,=========System looking for assembly: Vanilla.resources,, Version=4.0.0.0,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.0231,Debug,,Destiny =========System looking for assembly: Vanilla.resources,, Version=4.0.0.0,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.0231,Debug,,=========System looking for assembly: Vanilla.resources,, Version=4.0.0.0,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.0231,Debug,,Destiny =========System looking for assembly: Vanilla.resources,, Version=4.0.0.0,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.0611,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Vanilla-strings-en.xml,1,Application 2014-02-19 10:46:55.0770,Info,,Vanilla (version 4.0.0.0) Theme Loaded.,1,Application 2014-02-19 10:46:55.0780,Info,,Plugin Loading and Init took 0.61 seconds.,1,Application 2014-02-19 10:46:55.0821,Info,,*** Theme in use is: Chocolate,1,Application 2014-02-19 10:46:55.1211,Debug,,=========System looking for assembly: WebSocket4Net,, Version=0.8.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a,1,Application 2014-02-19 10:46:55.1211,Info,,Resolving WebSocket4Net,, Version=0.8.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a to C:\ProgramData\MediaBrowser-Classic\websocket4net.dll,1,Application 2014-02-19 10:46:55.1681,Info,,Connected to ws://192.168.1.7:8945/mediabrowser,1,Application 2014-02-19 10:46:55.1781,Debug,,Loading display prefs for C:\Users\administrator.RJNET\AppData\Roaming\MediaBrowser-Server\root\default,1,Application 2014-02-19 10:46:55.1841,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/b21ccc945ed35ac08c3b35d5de9e71f3?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,1,Application 2014-02-19 10:46:55.2471,Debug,,Sorting Media Library,1,Application 2014-02-19 10:46:55.2681,Info,,Application Init took 2.15 seconds.,1,Application 2014-02-19 10:46:55.3121,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=46cde088-2831-49e2-a94b-7a8451e0e5e0&sortBy=&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,OriginalRunTimeTicks,,MediaStreams,,SortName,,Taglines&ImageTypes=&recursive=False&genres=&Ids=&studios=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personTypes=&years=&format=Json,27,Worker thread for Background Sorter 2014-02-19 10:46:55.9341,Debug,,=========System looking for assembly: Chocolate,1,Application 2014-02-19 10:46:55.9341,Info,,Resolving plug-in reference to: Chocolate,1,Application 2014-02-19 10:46:55.9341,Debug,,=========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.9341,Debug,,Destiny =========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.9351,Debug,,=========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.9351,Debug,,Destiny =========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en-US,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.9351,Debug,,=========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.9351,Debug,,Destiny =========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.9351,Debug,,=========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:55.9351,Debug,,Destiny =========System looking for assembly: Chocolate.resources,, Version=3.0.4.1,, Culture=en,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2014-02-19 10:46:56.2311,Debug,,=========System looking for assembly: BDScreenSaver,1,Application 2014-02-19 10:46:56.2322,Info,,Resolving plug-in reference to: BDScreenSaver,1,Application 2014-02-19 10:46:56.2331,Debug,,=========System looking for assembly: BDScreenSaver.resources,, Version=2.0.0.3,, Culture=en-US,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:56.2331,Debug,,Destiny =========System looking for assembly: BDScreenSaver.resources,, Version=2.0.0.3,, Culture=en-US,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:56.2331,Debug,,=========System looking for assembly: BDScreenSaver.resources,, Version=2.0.0.3,, Culture=en-US,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:56.2331,Debug,,Destiny =========System looking for assembly: BDScreenSaver.resources,, Version=2.0.0.3,, Culture=en-US,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:56.2331,Debug,,=========System looking for assembly: BDScreenSaver.resources,, Version=2.0.0.3,, Culture=en,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:56.2331,Debug,,Destiny =========System looking for assembly: BDScreenSaver.resources,, Version=2.0.0.3,, Culture=en,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:56.2341,Debug,,=========System looking for assembly: BDScreenSaver.resources,, Version=2.0.0.3,, Culture=en,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:56.2341,Debug,,Destiny =========System looking for assembly: BDScreenSaver.resources,, Version=2.0.0.3,, Culture=en,, PublicKeyToken=307c6ce4e08b837b,1,Application 2014-02-19 10:46:56.3051,Debug,,Loading display prefs for C:\Users\administrator.RJNET\AppData\Roaming\MediaBrowser-Server\root\default,1,Application 2014-02-19 10:46:56.3051,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/b21ccc945ed35ac08c3b35d5de9e71f3?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,1,Application 2014-02-19 10:46:56.3187,Debug,,Sorting Media Library,1,Application 2014-02-19 10:46:56.4197,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=e711e7cd-1b9b-bf1f-634a-1db8e8059ca0&sortBy=&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,OriginalRunTimeTicks,,MediaStreams,,SortName,,Taglines&ImageTypes=&recursive=False&genres=&Ids=&studios=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personTypes=&years=&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:46:56.4577,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Localization/ParentalRatings?format=Json,1,Application 2014-02-19 10:46:56.6007,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/e711e7cd1b9bbf1f634a1db8e8059ca0?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:46:56.7127,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/MediaInfo/Chocolate%2frated_none,1,Application 2014-02-19 10:46:56.7381,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_none being cached on first access. Should only have to do this once per session...,1,Application 2014-02-19 10:46:56.7721,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Primary?maxWidth=350&Quality=90,44,Worker thread for Aspect Ratio Calculator 2014-02-19 10:46:56.8291,Error,,Error getting response from http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Primary?maxWidth=350&Quality=90 ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),44,Worker thread for Aspect Ratio Calculator 2014-02-19 10:46:56.8331,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Primary?maxWidth=350&Quality=90,44,Worker thread for Aspect Ratio Calculator 2014-02-19 10:46:56.8641,Error,,Failed to download image: http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Primary?maxWidth=350&Quality=90 ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.Library.ImageManagement.RemoteImage.DownloadImage() [n] at MediaBrowser.Library.ImageManagement.RemoteImage.DownloadUsingRetry() ),44,Worker thread for Aspect Ratio Calculator 2014-02-19 10:46:56.8641,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Primary?maxWidth=350&Quality=90,44,Worker thread for Aspect Ratio Calculator 2014-02-19 10:46:56.8921,Error,,Failed to download image: http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Primary?maxWidth=350&Quality=90 ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.Library.ImageManagement.RemoteImage.DownloadImage() [n] at MediaBrowser.Library.ImageManagement.RemoteImage.DownloadUsingRetry() ),44,Worker thread for Aspect Ratio Calculator 2014-02-19 10:46:56.9921,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=e711e7cd-1b9b-bf1f-634a-1db8e8059ca0&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,OriginalRunTimeTicks,,IndexOptions,,SortName,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,MediaStreams,,ParentId&Filters=IsUnplayed&ImageTypes=&recursive=True&genres=&Ids=&studios=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&ExcludeLocationTypes=Virtual&personTypes=&years=&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:46:57.0286,Info,,RAL child retrieval for Concert's And Music option unwatched took 0.06 seconds.,45,Worker thread for Newest Item Loader 2014-02-19 10:46:57.0286,Debug,,unwatched list for Concert's And Music loaded with 20 items.,45,Worker thread for Newest Item Loader 2014-02-19 10:46:57.0446,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/f5fcc10c-5ed4-4236-3510-f513b567f1b9?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:46:57.2487,Info,,Information DisplayText: Welcome to Media Browser,1,Application 2014-02-19 10:47:00.4062,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=362d1d17-0e07-4acf-876d-c524b75abc03&sortBy=&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,OriginalRunTimeTicks,,MediaStreams,,SortName,,Taglines&ImageTypes=&recursive=False&genres=&Ids=&studios=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personTypes=&years=&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:47:00.4262,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/362d1d170e074acf876dc524b75abc03?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:47:00.5684,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=362d1d17-0e07-4acf-876d-c524b75abc03&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,OriginalRunTimeTicks,,IndexOptions,,SortName,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,MediaStreams,,ParentId&Filters=IsUnplayed&ImageTypes=&recursive=True&genres=&Ids=&studios=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&ExcludeLocationTypes=Virtual&personTypes=&years=&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:00.5874,Info,,RAL child retrieval for DEMOS option unwatched took 0.02 seconds.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:00.5874,Debug,,unwatched list for DEMOS loaded with 11 items.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:00.5874,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/f5fcc10c-5ed4-4236-3510-f513b567f1b9?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.1810,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=cc1c0c5f-f24b-4280-3fdd-9e2f24414871&sortBy=&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,OriginalRunTimeTicks,,MediaStreams,,SortName,,Taglines&ImageTypes=&recursive=False&genres=&Ids=&studios=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personTypes=&years=&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:47:01.2070,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/cc1c0c5ff24b42803fdd9e2f24414871?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:47:01.3380,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=cc1c0c5f-f24b-4280-3fdd-9e2f24414871&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,OriginalRunTimeTicks,,IndexOptions,,SortName,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,MediaStreams,,ParentId&Filters=IsUnplayed&ImageTypes=&recursive=True&genres=&Ids=&studios=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&ExcludeLocationTypes=Virtual&personTypes=&years=&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.3680,Info,,RAL child retrieval for Documentaries option unwatched took 0.03 seconds.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.3680,Debug,,unwatched list for Documentaries loaded with 20 items.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.3680,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/f5fcc10c-5ed4-4236-3510-f513b567f1b9?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.3830,Warning,,Image is Corrupt.,41,Net Image loader-Worker 2014-02-19 10:47:01.3840,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Backdrop?maxWidth=1920&Quality=90,1,Application 2014-02-19 10:47:01.4151,Error,,Error getting response from http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Backdrop?maxWidth=1920&Quality=90 ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),1,Application 2014-02-19 10:47:01.4221,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Backdrop?maxWidth=1920&Quality=90,42,Net Image loader-Worker 2014-02-19 10:47:01.4491,Error,,Failed to download image: http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Backdrop?maxWidth=1920&Quality=90 ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.Library.ImageManagement.RemoteImage.DownloadImage() [n] at MediaBrowser.Library.ImageManagement.RemoteImage.DownloadUsingRetry() ),42,Net Image loader-Worker 2014-02-19 10:47:01.4491,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Backdrop?maxWidth=1920&Quality=90,42,Net Image loader-Worker 2014-02-19 10:47:01.4778,Error,,Failed to download image: http://192.168.1.7:8096/mediabrowser/Images/General/Favorites/Backdrop?maxWidth=1920&Quality=90 ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.Library.ImageManagement.RemoteImage.DownloadImage() [n] at MediaBrowser.Library.ImageManagement.RemoteImage.DownloadUsingRetry() ),42,Net Image loader-Worker 2014-02-19 10:47:01.4778,Warning,,Image is Corrupt.,42,Net Image loader-Worker 2014-02-19 10:47:01.5786,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=46cde088-2831-49e2-a94b-7a8451e0e5e0&limit=50&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,OriginalRunTimeTicks,,IndexOptions,,SortName,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,MediaStreams,,ParentId&Filters=IsUnplayed,,IsFavorite&ImageTypes=&recursive=True&genres=&Ids=&studios=&ExcludeItemTypes=&ExcludeLocationTypes=Virtual&personTypes=&years=&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.5916,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=55ed9095-587b-3495-aec2-4077768ec703&sortBy=&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,OriginalRunTimeTicks,,MediaStreams,,SortName,,Taglines&ImageTypes=&recursive=False&genres=&Ids=&studios=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personTypes=&years=&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:47:01.6016,Info,,RAL child retrieval for Favorites option unwatched took 0.02 seconds.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.6016,Debug,,unwatched list for Favorites loaded with 0 items.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.6126,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/55ed9095587b3495aec24077768ec703?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:47:01.7471,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=55ed9095-587b-3495-aec2-4077768ec703&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,OriginalRunTimeTicks,,IndexOptions,,SortName,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,MediaStreams,,ParentId&Filters=IsUnplayed&ImageTypes=&recursive=True&genres=&Ids=&studios=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&ExcludeLocationTypes=Virtual&personTypes=&years=&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.7814,Info,,RAL child retrieval for Fitness option unwatched took 0.03 seconds.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.7814,Debug,,unwatched list for Fitness loaded with 1 items.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:01.7814,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/f5fcc10c-5ed4-4236-3510-f513b567f1b9?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:02.2861,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=c883555e-169a-96e8-9665-087b5d49d999&sortBy=&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,OriginalRunTimeTicks,,MediaStreams,,SortName,,Taglines&ImageTypes=&recursive=False&genres=&Ids=&studios=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personTypes=&years=&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:47:04.0848,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items?ParentId=c883555e-169a-96e8-9665-087b5d49d999&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,OriginalRunTimeTicks,,IndexOptions,,SortName,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,MediaStreams,,ParentId&Filters=IsUnplayed&ImageTypes=&recursive=True&genres=&Ids=&studios=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&ExcludeLocationTypes=Virtual&personTypes=&years=&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:04.0988,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/c883555e169a96e89665087b5d49d999?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,37,Worker thread for Overview Loader 2014-02-19 10:47:04.1300,Info,,RAL child retrieval for Movies option unwatched took 0.05 seconds.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:04.1300,Debug,,unwatched list for Movies loaded with 20 items.,45,Worker thread for Newest Item Loader 2014-02-19 10:47:04.1300,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/DisplayPreferences/f5fcc10c-5ed4-4236-3510-f513b567f1b9?userId=9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41&client=MBC&format=Json,45,Worker thread for Newest Item Loader 2014-02-19 10:47:05.0008,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/MediaInfo/Chocolate%2frated_r,1,Application 2014-02-19 10:47:05.0221,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_r being cached on first access. Should only have to do this once per session...,1,Application 2014-02-19 10:47:07.3670,Debug,,Loading full details for Skinwalker Ranch actors: null,1,Application 2014-02-19 10:47:07.3730,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items/8cc90900-e431-bafa-e638-689c07dc86f9?format=Json,1,Application 2014-02-19 10:47:07.7428,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Localization/ParentalRatings?format=Json,1,Application 2014-02-19 10:47:07.7538,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/MediaInfo/Chocolate%2fcodec_h264,1,Application 2014-02-19 10:47:07.7766,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_h264 being cached on first access. Should only have to do this once per session...,1,Application 2014-02-19 10:47:07.7826,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/MediaInfo/Chocolate%2fcodec_dts_ds,1,Application 2014-02-19 10:47:07.8068,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_dts_ds being cached on first access. Should only have to do this once per session...,1,Application 2014-02-19 10:47:07.8108,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/MediaInfo/Chocolate%2fchannels_6,1,Application 2014-02-19 10:47:07.8306,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/channels_6 being cached on first access. Should only have to do this once per session...,1,Application 2014-02-19 10:47:07.8357,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/MediaInfo/Chocolate%2faspect_177,1,Application 2014-02-19 10:47:07.8569,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/aspect_177 being cached on first access. Should only have to do this once per session...,1,Application 2014-02-19 10:47:07.8619,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/MediaInfo/Chocolate%2fhdtype_1080,1,Application 2014-02-19 10:47:07.8822,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/hdtype_1080 being cached on first access. Should only have to do this once per session...,1,Application 2014-02-19 10:47:07.8862,Debug,,Fetching image: http://192.168.1.7:8096/mediabrowser/Images/MediaInfo/Chocolate%2fmedia_mkv,1,Application 2014-02-19 10:47:07.9068,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/media_mkv being cached on first access. Should only have to do this once per session...,1,Application 2014-02-19 10:47:10.2882,Info,,Internal Player about to play Skinwalker Ranch(\\rjserver2\video 1\Movies\Skinwalker Ranch (2013)\Skinwalker.Ranch.2013.1080p.BluRay.x264-G3LHD.mkv) ,48,Worker thread for Play Action 2014-02-19 10:47:10.3270,Info,,Internal Player playing Skinwalker Ranch,48,Worker thread for Play Action 2014-02-19 10:47:10.3380,Debug,,Calling MediaCenterEnvironment.PlayMedia,1,Application 2014-02-19 10:47:11.4436,Debug,,Going fullscreen,1,Application 2014-02-19 10:47:11.4626,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2014-02-19 10:47:11.8346,Debug,,HandlePropertyChange has recognized that playback has started,1,Application 2014-02-19 10:47:11.8376,Debug,,Sending Http Post to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/PlayingItems/8cc90900-e431-bafa-e638-689c07dc86f9?CanSeek=True&QueueableMediaTypes=&format=Json,1,Application 2014-02-19 10:47:11.9626,Debug,,Setting now playing status to True,1,Application 2014-02-19 10:47:11.9636,Debug,,Playstate changed to Playing for Skinwalker Ranch,, PositionTicks:0,, Playlist Index:0,1,Application 2014-02-19 10:47:11.9636,Debug,,Back from PlayStateChanged,1,Application 2014-02-19 10:47:11.9636,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2014-02-19 10:47:12.4433,Info,,Received web socket message: UserDataChanged,49, 2014-02-19 10:47:15.6513,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2014-02-19 10:47:15.9963,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2014-02-19 10:47:21.0564,Debug,,Sending Http Post to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/PlayingItems/8cc90900-e431-bafa-e638-689c07dc86f9/Progress?positionTicks=49906458&isPaused=False&isMuted=False&format=Json,51,Worker thread for BasePlaybackController OnProgress 2014-02-19 10:47:24.6613,Debug,,Playstate changed to Stopped for Skinwalker Ranch,, PositionTicks:84825209,, Playlist Index:0,1,Application 2014-02-19 10:47:24.6613,Debug,,Sending Http Post to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/PlayingItems/8cc90900-e431-bafa-e638-689c07dc86f9/Progress?positionTicks=84825209&isPaused=False&isMuted=False&format=Json,51,Worker thread for BasePlaybackController OnProgress 2014-02-19 10:47:24.6613,Debug,,Back from PlayStateChanged,1,Application 2014-02-19 10:47:24.6613,Debug,,Calling HandleStopedState,1,Application 2014-02-19 10:47:24.6633,Debug,,In HandleStoppedState,1,Application 2014-02-19 10:47:24.6643,Debug,,Events unhooked,1,Application 2014-02-19 10:47:24.6673,Debug,,Turning off NPV,1,Application 2014-02-19 10:47:24.6683,Debug,,Setting now playing status to False,1,Application 2014-02-19 10:47:24.6733,Debug,,Internal Player playback finished,11,Worker thread for Playback Finished 2014-02-19 10:47:24.6773,Debug,,Sending Http Post to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/PlayingItems/8cc90900-e431-bafa-e638-689c07dc86f9/Progress?positionTicks=84825209&isPaused=False&isMuted=False&format=Json,11,Worker thread for Playback Finished 2014-02-19 10:47:24.7022,Debug,,Reporting stopped to server for Skinwalker Ranch,11,Worker thread for Playback Finished 2014-02-19 10:47:24.7092,Debug,,Sending Http Delete to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/PlayingItems/8cc90900-e431-bafa-e638-689c07dc86f9?positionTicks=84825209,11,Worker thread for Playback Finished 2014-02-19 10:47:24.7175,Info,,Sending Http Get to http://192.168.1.7:8096/mediabrowser/Users/9e9ef1f8-db2b-2b79-f8b1-7b9e53fd7f41/Items/8cc90900-e431-bafa-e638-689c07dc86f9?format=Json,11,Worker thread for Playback Finished 2014-02-19 10:47:24.7402,Debug,,Setting new status on Skinwalker Ranch with parent of Movies,11,Worker thread for Playback Finished 2014-02-19 10:47:24.7432,Debug,,Firing Application.PlaybackFinished for: Skinwalker Ranch,11,Worker thread for Playback Finished 2014-02-19 10:47:24.7462,Debug,,Updating Resume status...,11,Worker thread for Playback Finished 2014-02-19 10:47:24.7482,Debug,,All post-playback actions have completed.,11,Worker thread for Playback Finished 2014-02-19 10:47:25.2192,Info,,Received web socket message: UserDataChanged,49,
ebr 16343 Posted February 19, 2014 Posted February 19, 2014 How did you play that item? Intros are only called when you play by pressing the play button on the detail page. This is by design so that it is possible to easily play something without intros.
JeremyFr79 228 Posted February 19, 2014 Author Posted February 19, 2014 I used play on the details page, like I said it's only not working with some recently added items, other movies that already existed on the server seem to call intros just fine.
ebr 16343 Posted February 19, 2014 Posted February 19, 2014 We aren't even attempting to look for Intros. Are you sure these items are considered Movies to MB and not just videos or something else?
JeremyFr79 228 Posted February 20, 2014 Author Posted February 20, 2014 They're in one of my 2 main movies drives/folders and are MKV files no different than my other content. The 2 movies that I know are affected are Hours and Skinwalker Ranch
JeremyFr79 228 Posted February 20, 2014 Author Posted February 20, 2014 Ok correction, it appears to be any movie added to my collection after February 8th that this is happening with.
ebr 16343 Posted February 20, 2014 Posted February 20, 2014 If you bring up the special "Movies" view in the web client (not your media folder of movies but the view at the top) do these items appear there? If so, please post screenshots of a couple of their edit pages.
JeremyFr79 228 Posted February 21, 2014 Author Posted February 21, 2014 Sorry for taking so long, been nursing a wife who had surgery earlier this week, here's a couple of screenshots for you.
ebr 16343 Posted February 21, 2014 Posted February 21, 2014 Did they appear in the "Movies" view? Down lower on that edit page, there is a "Display Settings" section. What is in there?
JeremyFr79 228 Posted February 22, 2014 Author Posted February 22, 2014 Did they appear in the "Movies" view? Down lower on that edit page, there is a "Display Settings" section. What is in there? Yes they appear in the "Movies" view, Display settings has "treat image as" and it's blank like all my other movies
ebr 16343 Posted February 22, 2014 Posted February 22, 2014 Blank...? Look at your older movies that work. Does that field say "Movie"? I think the server has changed how it is filling in that field and that has tripped up MBC. Try typing "Movie" in there and saving and see if intros then work.
seansean1981 0 Posted February 22, 2014 Posted February 22, 2014 (edited) Hi Just to chime in i'm having similar problems. I recently refreshed my server pc ( full re-install from scratch ) and on setting everything back up, intros no longer worked whereas they did fine before the refresh. I'm running all the latest updates at the moment, have the same issue with the display settings field, older movies have an entry newer ones don't. For me though the intros don't work on any film, old or new, regardless of what is in the display settings field. I have tried manually typing it in aswell just to cover all bases. For reference the only othe rplugins I currently have installed are serverwmc and trailers. Edited February 22, 2014 by seansean1981
JeremyFr79 228 Posted February 22, 2014 Author Posted February 22, 2014 Ok so like SeanSean as part of my troubleshooting the other night I reinstalled Server, now intros is no longer working on any of my movies and all are blank in the "display settings" 1
JeremyFr79 228 Posted February 22, 2014 Author Posted February 22, 2014 Can also confirm typing Movie into display settings changes nothing.
ebr 16343 Posted February 22, 2014 Posted February 22, 2014 Are all of you who re-installed your server sure you got your supporter key back in there properly so that Intros will be registered? Also, are any of you using tag-based intros?
JeremyFr79 228 Posted February 22, 2014 Author Posted February 22, 2014 Are all of you who re-installed your server sure you got your supporter key back in there properly so that Intros will be registered? Also, are any of you using tag-based intros? Tag based? I don't believe so, the only intro's I'm using is to play 2 random new trailers from the internet, and the sound format trailers that are locally stored, nothing else. And yes it shows my supporter key installed.
JeremyFr79 228 Posted February 23, 2014 Author Posted February 23, 2014 Ok, so I tried again tonight, I went into the movies I was having issue with and put Movie into "Display Settings" and now intro's works with them. So this seems to correct the issue, however am I going to have to do this from now on for every single movie I add to my collection?
ebr 16343 Posted February 23, 2014 Posted February 23, 2014 No. I just was not aware that the server changed its behaviour in this regard so MBC needs to change to adjust to it.
seansean1981 0 Posted February 23, 2014 Posted February 23, 2014 Typing in movie didnt work for me but the new update I got through last night seems to have fixed it, thanks
Mopar_Mudder 14 Posted February 25, 2014 Posted February 25, 2014 I have the same thing going on with MBT. I installed server Version 3.0.5168.16132 last night, and MBT tonight. I get no intros at all. My Display setting says Blu-Ray, changing to movie doesn't fix it.
JeremyFr79 228 Posted February 25, 2014 Author Posted February 25, 2014 The newest server release and intros release seems to have solved the problem for me.
