tdiguy 99 Posted June 18, 2017 Posted June 18, 2017 I cant seem to get this error to go away. I cant scan my libraries or update the guide. I tried clearing it by renaming: /var/lib/emby-server/data/library.db but no luck. Attaching the log: emby-error log.txt
tdiguy 99 Posted June 18, 2017 Author Posted June 18, 2017 Ok i finally got it working, seems there was an issue with one of my syn jobs ( i think ) i deleted all the syn jobs deleted the directory then rebooted the server. Once i did that it is able to scan again.
Solution Luke 42245 Posted June 18, 2017 Solution Posted June 18, 2017 It does not appear to be related to sync. See Corrupt: database disk image is malformed To repair this, you will need to rename this file /var/lib/emby-server/data/library.db Then after starting back up you'll need to run a library scan and guide refresh. Be aware this db file also contains user data (watch data), so you'll probably want to back that up: https://github.com/MediaBrowser/Wiki/wiki/Backup Or at least try to back it up, given a corrupt library.db file it is not guaranteed to be possible anymore. Let us know if this helps. Thanks. 1
