jimboz333 1 Posted February 18, 2014 Posted February 18, 2014 Has stopped working since I changed the computer holding my server. It's like it needs to be reset or something. I am not sure how to fix that up.
jordy 284 Posted February 18, 2014 Posted February 18, 2014 I had a similar problem when i relocated the server to a different pc, Solved it by deleting all the links in the boxset folder and refreshing the plugin.
jimboz333 1 Posted February 18, 2014 Author Posted February 18, 2014 Where would I find the box set folder? I had to start from scratch the whole harddrive burnt up I a starting completely from scratch.
ebr 16354 Posted February 18, 2014 Posted February 18, 2014 If you are talking about the Auto Box Sets plug-in you have to tell it where to put them.
