kingy444 117 Posted June 18, 2017 Posted June 18, 2017 (edited) The system seems to currently be unable to setup a new recording or series record. Have done so in the past without issue. Logs Attached Edited June 18, 2017 by kingy444
kingy444 117 Posted June 18, 2017 Author Posted June 18, 2017 right you are. here they are. obviously forgot to hit the 'attach this file' button :)y 63633406117.txt
Sven 136 Posted June 18, 2017 Posted June 18, 2017 When was the last time you updated your Guide? I see an error like this System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (404) Not Found. Do you also see the error in the nextpvr logs? We throw the "LiveTvConflictException" when we can't create the recording. But I don't see more information in the exception message.
kingy444 117 Posted June 18, 2017 Author Posted June 18, 2017 Logs.zipguide is updated automatically every morning and night (every 12 hours) while i couldn't schedule through emby, i spun up nextpvr manually and was able to record logs folder attached, not sure what you needed
Luke 42239 Posted June 18, 2017 Posted June 18, 2017 Sven has submitted an update for the plugin. Thanks @@Sven
Sven 136 Posted June 18, 2017 Posted June 18, 2017 (edited) @@Luke it was not for this issue. Still searching for the problem. Didn't find this one yet... Edited June 18, 2017 by Sven
Sven 136 Posted June 18, 2017 Posted June 18, 2017 (edited) @@sub3 I see the record in the "web.log" from nextpvr. Any idea why we see the error in Emby? Edited June 18, 2017 by Sven
kingy444 117 Posted June 18, 2017 Author Posted June 18, 2017 just curious, does the web.log record relate to the same time as the error in emby? after emby threw the error i went into nextpvr and manually set the record as mentioned.
Sven 136 Posted June 19, 2017 Posted June 19, 2017 It was a difference of 300ms. So you are probably not that fast.
sub3 64 Posted June 19, 2017 Posted June 19, 2017 @@sub3 I see the record in the "web.log" from nextpvr. Any idea why we see the error in Emby? I see a lot of these messages in the web.log: 2017-06-18 18:15:45.326 [iNFO][27] externl access not allowed via NPVR Allow Remote Access API setting. Is this access over the internet?
emveepee 133 Posted June 19, 2017 Posted June 19, 2017 Since you are using ipv6 localhost you might need this patch https://forums.nextpvr.com/showthread.php?58924-Web-Admin-Login-Fails-v3-9-2-(161119)&p=510729#post510729 I can't recall what was fixed. Martin
kingy444 117 Posted June 20, 2017 Author Posted June 20, 2017 i just tried changing http://localhost:8866 to http://127.0.0.1:8866 but have the same issue. i assume that rules out the ipv6 issue?
emveepee 133 Posted June 20, 2017 Posted June 20, 2017 (edited) I'd have to see the NextPVR logs. Also can you access that URL from a browser without a login prompt? Martin Edited June 20, 2017 by emveepee
Sven 136 Posted June 21, 2017 Posted June 21, 2017 @@emveepee he will post some new logs I received them via PM.. But I see this in the logs 2017-06-21 15:38:24.721 [DEBUG][20] ChannelOID: 7184 startDate: 1/01/0001 12:00:00 AM endDate: 1/01/0001 12:00:00 AM manualRecTitle: epgeventOID: 2721302 keyWord: scheduleOID: recurrOID: recDirId: recDir: rules: recurringName: The Last Ship qualityDefault: False qualityGood: False qualityBetter: False qualityBest: False pre_padding_min: 0 post_padding_min: 0 extend_end_time_min: 0 recurr_priority: 0 keep_all_days: False days_to_keep: 0 onlyNew: False isKeyword: False recordOnce: False recordThisTimeslot: False recordAnyTimeslot: True recordThisDay: False recordAnyDay: True recordSpecificdays: False dayMonday: True dayTuesday: True dayWednesday: True dayThursday: True dayFriday: True daySaturday: True daySunday: True allChannels: False recColorRed: False recColorYellow: False recColorGreen: False recColorBlue: False ......... 2017-06-21 15:38:24.722 [DEBUG][20] Unknown schedule record
sub3 64 Posted June 21, 2017 Posted June 21, 2017 (edited) The logs still seem to be full of errors about trying to do this remotely. kingy444, are you trying to access NextPVR on the local network, or across the internet? If the former, are you sure you're using a valid private address range? We've seen the occasional user with misconfigured network, using an invalid public address on their private network. It's receiving requests from 109.128.176.40, which is not valid private address that would be used on LAN. This is a public IP address. Edited June 21, 2017 by sub3
kingy444 117 Posted June 21, 2017 Author Posted June 21, 2017 (edited) emby and nextpvr are running on the same windows box (IP 10.0.0.42). Guide etc works fine, just recording seems to be broken though it has worked in the pastTo request the recording i run emby from my laptop (10.0.0.5) to start the recording. Note that if i run emby locally on 10.0.0.42 i get the same result as running on 10.0.0.5. Likely the logs you are seeing are related to While Sven is troubleshooting remotely i strangely was receiving the errors you speak of when just using my local LAN (see the first Logs attachement, the second is @Sven) Edited June 21, 2017 by kingy444
kingy444 117 Posted June 21, 2017 Author Posted June 21, 2017 I'd have to see the NextPVR logs. Also can you access that URL from a browser without a login prompt? Martin no - there is a login prompt
kingy444 117 Posted June 21, 2017 Author Posted June 21, 2017 see attached for a test i just performed (rebooted 10.0.0.42) and run from 10.0.0.5 logs-20170621-1844.zip server-63633667409.txt
emveepee 133 Posted June 21, 2017 Posted June 21, 2017 (edited) As sub posted your browser test is odd since it shows a public IP not private and it is different from the previous problem. The log messages for Emby seem odd too, so I still think you should upgrade with the patch, patches become part of the base package anyway. Also you should have been prompted to login. As for the problem Sven likely showed the real issue 2017-06-21 15:38:24.722 [DEBUG][20] Unknown schedule record Using a different client I did most of the testing for the NEWA JSON API and I see you appear to be trying a manual recording not a typical EPG based recording. My client doesn't do manual recordings so this could well be a server side bug. Do EPG based recordings work? Martin Edited June 21, 2017 by emveepee
Sven 136 Posted June 21, 2017 Posted June 21, 2017 @@emveepee But the EPG is coming from nextpvr. We use that same ID to send the request for the series recording...
emveepee 133 Posted June 21, 2017 Posted June 21, 2017 (edited) Sven, it seems to be coming in as a manual recording type not EPG based. I don't now how to create these with NEWA JSON but this line looks wrong for an EPG recording. recurringName: The Last Ship and earlier recurringName: True Story With Hamish & Andy Martin Edited June 21, 2017 by emveepee
kingy444 117 Posted June 21, 2017 Author Posted June 21, 2017 I can confirm that i was clicking series record, just plain record does the same thing. Selecting and item from the epg
sub3 64 Posted June 21, 2017 Posted June 21, 2017 Likely the logs you are seeing are related to While Sven is troubleshooting remotely i strangely was receiving the errors you speak of when just using my local LAN (see the first Logs attachement, the second is Sven)Ah, right. Ok, ignore my comments then. I've ask UJB to take a look at this thread. He developed the NEWA interface that Emby uses to talk to NextPVR. He is best placed to interpret what the log messages mean.
