JasonG 16 Posted June 15, 2017 Posted June 15, 2017 I have had SchedulesDirect for the last year, and it recently expired. Because we don't use Live TV very often (only a couple shows a week), I decided to look at other options. I have implemented an XMLTV solution with Zap2It, and everything is working as expected, except the previously scheduled series are not appearing in the listing to be recorded. I have to remove the old entry and add it back to have upcoming shows appear for recording. The visible names are identical (for instance, "Sesame Street"), however until I remove the old entry created while using SchedulesDirect and add it back from the guide, Emby doesn't list any upcoming recordings. Thoughts?
Luke 42243 Posted June 16, 2017 Posted June 16, 2017 You will need to remove and recreate your series recordings when changing guide providers. 1
