lolwut 16 Posted June 15, 2017 Posted June 15, 2017 (edited) Hi Luke On the latest version of Emby Server Library -> Metadata -> Metadata Readers does not appear on UI and xml files are not read by Emby Server Reverting back to 3.2.19 solves the problem I did not save the logs but, I did few uninstalls, clear cache, delete central metadata folders, delete db files, etc. and only getting old version, extracting on another path, deleting every trace solved. As I said I dont have the logs but, no notable errors relating to problem, for example, I remove a test folder (few movies - movie.xml), add it with another name with Movie content type, almost nothing on logs (debug mode), it just creates posters and views etc with no errors. I have the movie with backdrop, etc on the library with no data, on the folder it creates a fresh nfo right next to movie.xml file. (One more thing, so new fresh installation of 3.2.19 works great, but if it auto updates, and I restart the server, and I add new stuff, the xml files of new stuff doesnt get read, reverting back to 3.2.19 with no internet connection so it does not update works) Best Edited June 15, 2017 by lolwut
Solution PeteMB 13 Posted June 15, 2017 Solution Posted June 15, 2017 I think you need to install a plugin for that see here. 2
Happy2Play 9802 Posted June 15, 2017 Posted June 15, 2017 The Blog and Announcement say the same also. Emby Server 3.2.20 Released
lolwut 16 Posted June 15, 2017 Author Posted June 15, 2017 Thank you, didnt know that, thought it was a bug, not that the server is moving on
