Scrubsss 5 Posted June 14, 2017 Posted June 14, 2017 (edited) Ok first of all the important information: TV Samsung: UE40F6500 TV Firmware: T-MST12DEUC-2126.0 Samsung Emby-Client version: 2.2.2 Emby Server: 3.2.17.0 ffmpeg Version: N-52954-g295de3e-static I freshly installed the emby app on my samsung tv. Without transcoding all movies will be played back normal. But when i enable the badwith limit in app settings to a lower bitrate for example 3Mbps it starts to transcode the movie, wich is what i want. With AC3 audio codec everything works fine. But any movie with DTS audio fails to play. TV App Error is "Connection Error" In the server log i can see that the transcoding fails. Here the 2 Files Keep in mind that my default audio track is german. Logs attached and on pastebin https://pastebin.com/41hsR3tV. Any idea? logs.zip Edited June 14, 2017 by Scrubsss
Luke 42241 Posted June 15, 2017 Posted June 15, 2017 Hi, looks like a problem in the app. Just so you are aware, this is a community app built and maintained by community members. We are working very hard to make the official Emby Samsung app available for your older device: https://emby.media/emby-for-samsung-smart-tv.html Thanks !
Scrubsss 5 Posted June 15, 2017 Author Posted June 15, 2017 Is the community build still maintained, so someone can take a look at it? I think the Offical app can take a while right?
Luke 42241 Posted June 15, 2017 Posted June 15, 2017 Hopefully @@cmcg will see this and take a look. The official app works on the device so we are just trying to get it approved for release. thanks. 2
Scrubsss 5 Posted June 15, 2017 Author Posted June 15, 2017 Thanks for the help. cmcg is inaktive since a month, so i think it will take a while. Waiting for official app then, i will not ask for any eta on that because i know how annoying that is . BTW: keep going strong great project thank you for that. 1
cmcg 876 Posted June 28, 2017 Posted June 28, 2017 Hey @@Luke , check out the last line for the Pastebin link. [dca @ 0x418bcc0] The encoder 'dca' is experimental but experimental codecs are not enabled, add '-strict -2' if you want to use it. Is this a server config issue?
Luke 42241 Posted June 28, 2017 Posted June 28, 2017 Hey @@Luke , check out the last line for the Pastebin link. [dca @ 0x418bcc0] The encoder 'dca' is experimental but experimental codecs are not enabled, add '-strict -2' if you want to use it. Is this a server config issue? Notice on the query string you have AudioCodec=dca You're trying to encode to dca which is not possible. Or maybe it is but we've never tried it. In any case, if you're converting the audio try something more typical like aac or mp3, etc. 1
cmcg 876 Posted June 30, 2017 Posted June 30, 2017 OK, I think It's something to do with having multiple audio tracks. Line 66 is the the point at which we determine if we'll try to direct play. isVideo and isAudio refer to "is the video stream compatible for direct play on this TV model" and the same for audio (as determined by the tables in GuiPlayer_TranscodeParams.js) and convertAACtoDolby is a user preference which is generally false. But it looks like the original dev has decided that this will not work if the audio stream is not index 0. Is that so? 1
Luke 42241 Posted June 30, 2017 Posted June 30, 2017 I'm not familiar with that code, but lines 76 and 79 seem to be incorrectly assuming that the server can encode to the original audio codec. so that should be changed to something that is supported.
cmcg 876 Posted June 30, 2017 Posted June 30, 2017 Fixed. @@Scrubsss please install the beta version 2.2.3b from the IP address 82.27.106.58 and it should be fixed. Let me know how you get on. 4
Scrubsss 5 Posted July 1, 2017 Author Posted July 1, 2017 @@cmcg Thank you very much. All seems to work perfectly. I don't have much time to check a bunch of movies right now, but the ones i tested worked without problems. Big thanks to the Emby community. I am very happy right now.
cmcg 876 Posted July 1, 2017 Posted July 1, 2017 You are welcome. I'm not doing many updates to this version now but when a nice clear report comes in about a bug that has a noticeable effect playback, I'm happy to help. 2
