sd26 0 Posted June 14, 2017 Posted June 14, 2017 (edited) I downloaded the add-on (plugin.video.emby-develop) from GitHub directly and installed it manually 3 days ago after noticing initial support for Leia. It seems to work well with the Kodi 18 alpha Windows 64bit nightlies. I know Emby waits for Kodi to be at a later stage before releasing an update but if your willing to take the risk you can try it now. Edited June 14, 2017 by sd26
