georgewill76 14 Posted June 12, 2017 Posted June 12, 2017 Hi I need some help with MPAA/Parental ratings appearing in Kodi. I am using the latest emby server beta version with Kodi 17.3 front end on my htpc, using the Titan skin. I have emby server metadata setup as English-United Kingdom which means that for my movies the MPAA/Parental Rating shows up as GB-12, GB-15, etc. I have enabled media info/codecs view in Kodi but the information it displays for all m movies is NR, if I use large icons or coloured large icons. If I change the view to text only view it displays the parental rating as GB-12, GB-15, etc. Does anyone know if Kodi picks up the parental ratings a different way? Should it understand GB-** or should it be UK-**? I see on emby server the are two text files in localization, one for GB and one for UK, but I am unable to use the parental codes with UK at the beginning.
Angelblue05 4132 Posted June 12, 2017 Posted June 12, 2017 It depends on the skin support. But I'm pretty sure GB should work. @@marcelveldt what is the UK rating system for your skin? Sent from my iPhone using Tapatalk
