Painkiller88 250 Posted June 4, 2022 Posted June 4, 2022 2 minutes ago, Banquero said: Y como se deshabilita el núcleo en el servidor? Gracias esto se puede encontrar en la pestaña avanzada de la configuración de la biblioteca, sólo tiene que establecer la detección de introducción a nunca
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 (edited) 25 minutes ago, Banquero said: Y como se deshabilita el núcleo en el servidor? Gracias There is no need - just remove the Scheduled Task by deleting the schedule. To note - if you don't have the schedule, then it won't be running. Edited June 4, 2022 by rbjtech
Banquero 38 Posted June 4, 2022 Posted June 4, 2022 Estoy hecho un lío...A ver, esta imagen que aparece en las tareas programadas, coirresponde al núcleo o al plugin?...Muchas gracias...
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 7 minutes ago, Banker said: I'm in a mess... Let's see, this image that appears in the scheduled tasks, corresponds to the core or the plugin?... Thanks a lot... The above is from the Plugin - do not disable any of that. If you do not see a 'Detect Episode Intros' entry in the schedule ( In the Library section) - then you have nothing to worry about. If you do, then just remove the schedule for it as shown above.
Banquero 38 Posted June 4, 2022 Posted June 4, 2022 2 minutes ago, rbjtech said: The above is from the Plugin - do not disable any of that. If you do not see a 'Detect Episode Intros' entry in the schedule ( In the Library section) - then you have nothing to worry about. If you do, then just remove the schedule for it as shown above. Efectivamente no veo esa tarea programada en Library...Muchas gracias por vuestra ayuda...
ebr 16338 Posted June 4, 2022 Posted June 4, 2022 7 hours ago, rbjtech said: no auto-skip option The core feature includes auto skip as an option.
rbjtech 5345 Posted June 4, 2022 Posted June 4, 2022 3 minutes ago, ebr said: The core feature includes auto skip as an option. Hi Eric - by options I meant a message is displayed as an option but to be fair the core may display a message too, I haven't checked the latest release.
ebr 16338 Posted June 4, 2022 Posted June 4, 2022 9 minutes ago, rbjtech said: Hi Eric - by options I meant a message is displayed as an option but to be fair the core may display a message too, I haven't checked the latest release. Android TV app displays a message on auto-skip. I think this is necessary if you are auto skipping. 1
AndyXH 78 Posted June 5, 2022 Posted June 5, 2022 Hi all I see in 4.7.2.0 skip intro can be enabled in the folder library but I don’t see any option to run the scan. Can anyone point me to the right direction please
Oracle 86 Posted June 5, 2022 Posted June 5, 2022 Does someone have a video of this plugin in action - just curious what it looks like before I go through the process of install and config
Arsyad1105 0 Posted June 5, 2022 Posted June 5, 2022 Hi. Intro Skip not showing anymore on my emby plugin. How to fix this?
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 16 hours ago, ebr said: Android TV app displays a message on auto-skip. I think this is necessary if you are auto skipping. ok thanks. I have corrected the statement in the post.
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 7 hours ago, andreaxheli said: Hi all I see in 4.7.2.0 skip intro can be enabled in the folder library but I don’t see any option to run the scan. Can anyone point me to the right direction please This thread is for the Plugin - you need to review the thread below for official support - thanks. https://emby.media/community/index.php?/topic/107673-testing-intro-skipping/
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 7 hours ago, Arly (Sprinkles) said: Does someone have a video of this plugin in action - just curious what it looks like before I go through the process of install and config Hi - Have a look at the official Plugin Wiki as that will give you a good idea on what to expect. https://github.com/chefbennyj1/Emby.IntroSkip.Release/wiki To note - If you just want Intro's - then I would suggest going with the official core implementation at this very late stage (the plugin has been available for well over a year..) as we are going through the process of moving parts of the Plugin to it anyway.
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 2 hours ago, Arsyad1105 said: Hi. Intro Skip not showing anymore on my emby plugin. How to fix this? https://github.com/chefbennyj1/Emby.IntroSkip.Release/wiki Have a look here first - if you still have questions, then please supply more information, error messages, screen shots and/or logs etc so we can help you.
Arsyad1105 0 Posted June 5, 2022 Posted June 5, 2022 47 minutes ago, rbjtech said: https://github.com/chefbennyj1/Emby.IntroSkip.Release/wiki Have a look here first - if you still have questions, then please supply more information, error messages, screen shots and/or logs etc so we can help you. None of it helping unfortunately I don't get any errors from emby. I've already installed before and it showing but now it's gone without any errors or anything. The dll file still there.
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 (edited) 16 minutes ago, Arsyad1105 said: None of it helping unfortunately I don't get any errors from emby. I've already installed before and it showing but now it's gone without any errors or anything. The dll file still there. Ah - if you have recently updated emby, then you need to manually delete the IntroSkip.DLL from the plugins directory (only the DLL, do not delete anything else) and then install the IntroSkip Plugin from the Emby catalog - it's in the General section. It will continue to use the previous Introskip Plugin data - and if you run the Chapter Task, it will now also import the data to use the manual button if you wish. The old version was incompatible with the new Core Introskip, so it needs an update and will be disabled if you are still using the old one - that is probably the issue here. Edited June 5, 2022 by rbjtech
Arsyad1105 0 Posted June 5, 2022 Posted June 5, 2022 22 minutes ago, rbjtech said: Ah - if you have recently updated emby, then you need to manually delete the IntroSkip.DLL from the plugins directory (only the DLL, do not delete anything else) and then install the IntroSkip Plugin from the Emby catalog - it's in the General section. It will continue to use the previous Introskip Plugin data - and if you run the Chapter Task, it will now also import the data to use the manual button if you wish. The old version was incompatible with the new Core Introskip, so it needs an update and will be disabled if you are still using the old one - that is probably the issue here. Thank you. I'm not regularly manage Emby server so I'm not keep updated always
Arsyad1105 0 Posted June 5, 2022 Posted June 5, 2022 2 hours ago, rbjtech said: Ah - if you have recently updated emby, then you need to manually delete the IntroSkip.DLL from the plugins directory (only the DLL, do not delete anything else) and then install the IntroSkip Plugin from the Emby catalog - it's in the General section. It will continue to use the previous Introskip Plugin data - and if you run the Chapter Task, it will now also import the data to use the manual button if you wish. The old version was incompatible with the new Core Introskip, so it needs an update and will be disabled if you are still using the old one - that is probably the issue here. Huh, this plugin isn't available on Linux. Is it doesn't work for Linux?
rbjtech 5345 Posted June 5, 2022 Posted June 5, 2022 7 minutes ago, Arsyad1105 said: Huh, this plugin isn't available on Linux. Is it doesn't work for Linux? Pass - I believe it does, but need somebody with Linux experience to help you on that.
samuelqwe 317 Posted June 5, 2022 Posted June 5, 2022 4 hours ago, rbjtech said: Pass - I believe it does, but need somebody with Linux experience to help you on that. 4 hours ago, Arsyad1105 said: Huh, this plugin isn't available on Linux. Is it doesn't work for Linux? Should work just fine, make sure you’re using the latest version of Emby Server and look for the plugin in the catalog from a web browser, not the mobile app. 1
neik 874 Posted June 5, 2022 Posted June 5, 2022 In the plugin one is able to set up which users can use the skip intro information. Is this still a thing now that we have the core skip button?
samuelqwe 317 Posted June 5, 2022 Posted June 5, 2022 1 hour ago, neik said: In the plugin one is able to set up which users can use the skip intro information. Is this still a thing now that we have the core skip button? The core implementation allows each user to either: see the button, auto-skip or not have either. You can find these options in the playback settings of each user. The plugin doesn’t have access to these settings and can’t control them. Both the plugin and the core implementation have auto-skip and both operate independently.
Banquero 38 Posted June 5, 2022 Posted June 5, 2022 Buenas noches, tengo activado el plugin y funciona perfectamente. Como cliente tengo Android TV beta 2.0.7.5a para Fire Tv. He leído que también aparece el cartel Next Up para saltar los créditos, pero a mi no me aparece. Tengo que activar algo? Muchas gracias...
Cheesegeezer 3106 Posted June 5, 2022 Posted June 5, 2022 (edited) 29 minutes ago, Banker said: Good evening, I have activated the plugin and it works perfectly. As a client I have Android TV beta 2.0.7.5a for Fire Tv. I have read that the Next Up sign also appears to skip the credits, but it does not appear for me. Do I have to activate something? Thank you very much... Hello, just so we can be clear. All the plugin does is create intro start and end points. And credit start points. if you active the chapter task in the plugin this will create the rewuired chapter points only in each episode if there is one. if you use the plugins autoskip feature or end credit skip feature then this will work. anything to do with intro skip buttons displaying and next episode pop ups are to do with emby core implementation. we are in a transition phase at the moment and the core will pick up most of what the plugin does. What the core doesn’t take from the plugin the plugin will continue to do that extra work. @Luke @ebr i think this is correct. Would you like to add anything Edited June 5, 2022 by Cheesegeezer
