ads 2 Posted June 12, 2017 Posted June 12, 2017 HI Guys Had this issue for a while When watching a movie on the firetv it often pauses the Audio and then carries on Every 20 seconds or so the Audio is dropped for a second or so It is direct playing when i check in on the server from the ios app Changing the option that pops...says something like do you have audio or video problems solves the problem. This is the setting that you get whilst your playing the video The question is how to default to this player that is being selected in this popup, i guessing Emby has 2 or more player by default? It plays fine with LIve TV Thanks Adrian
ebr 16337 Posted June 13, 2017 Posted June 13, 2017 When you do that it is probably switching to transcoding. What are the specifics of the item with this problem? Is it a high bitrate DD stream?
