skivy71 5 Posted June 12, 2017 Posted June 12, 2017 Hi, Can the emby theatre client do client side deinterlacing for Live TV, like using hardware (DXVA etc.) in the same way that WMC, Kodi etc does? Seem's like using ffmpeg to transcode, just to deinterlace should be avoided where possible. Kind regards, Neil
Jdiesel 1435 Posted June 12, 2017 Posted June 12, 2017 I believe that server side deinterlacing in only used when the client does not support deinterlacing on the player side. If I recall correctly the new ET must has deinterlace set to "Yes" and not "Auto".
Luke 42243 Posted June 12, 2017 Posted June 12, 2017 Yes it can, just enable it under app video settings.
skivy71 5 Posted June 12, 2017 Author Posted June 12, 2017 Hi Luke, Does this apply to theatre for windows too? Not seen any client side settings :-/
Luke 42243 Posted June 12, 2017 Posted June 12, 2017 For the desktop app yes, not the store app. But for the store app you can install the Microsoft mpeg2 extension. See our recent blog announcement about that.
skivy71 5 Posted June 12, 2017 Author Posted June 12, 2017 I'm using the standard desktop Emby Theatre on Windows 7. I've just opened it and feel a little stupid... I cannot find any settings anywhere :-/
