neptunepic
Hi all, I've installed Emby Theater and while the install seems to have happened normally, but when I run the program I don't see any UI, just big blocks of black and white.
Now, I'm accessing the server remotely so is it possible I'm not seeing anything because the overlay doesn't function properly when viewing remotely?
I'll try looking locally when I get home but figured it would be worth knowing the answer.
Thanks!
Can you show a screenshot? Thanks !
neptunepic
Screenshot attached.
Also, the software is not starting full screen but in a window, as you can see.
