weaselbran 0 Posted June 7, 2017 Posted June 7, 2017 Recently, I had to install a new hard drive and move the tv shows to the new drive. After running the scan library everything looks great and some of the episodes are sorted correctly by auto organize; however, one show is consistently sorting to the old drive which is not part of the tv library. How do I delete/edit the auto organize entry so I can get it sorted correctly?
Luke 42217 Posted June 8, 2017 Posted June 8, 2017 Check your library setup in Emby. Are you sure that none of the old paths are hanging around?
weaselbran 0 Posted June 14, 2017 Author Posted June 14, 2017 I have verified the library settings. Now, three shows are being directed to the incorrect drive.
Luke 42217 Posted June 15, 2017 Posted June 15, 2017 @@weaselbran, please discuss some specific examples, and attach the information requested in how to report a problem. thanks !
Mdrodge 0 Posted April 25, 2019 Posted April 25, 2019 I'm having the same issue with my unraid server. I've tried uninstalling / reinstalling the plugin twice. I'm going to do a complete emby uninstall now. That should fix it. It is does it with any new file not just some shows. It just doesn't care that the library is in a new location and moves every thing to the old path.
Luke 42217 Posted April 25, 2019 Posted April 25, 2019 Hi @@Mdrodge please see my previous posting. Thanks !
