shsharpe 0 Posted June 7, 2017 Posted June 7, 2017 (edited) Recently pin to taskbar stopped working in Windows. Before when trying to pin it pined Emby Theater like expected but recently when trying to pin it will just pin Electron which results in it launching an Electron window, not Emby Theater. Edited June 7, 2017 by shsharpe
Luke 42241 Posted June 7, 2017 Posted June 7, 2017 Hi, this is a known issue for now that we'll resolve in a coming update. thanks for the report.
Sammy 791 Posted June 7, 2017 Posted June 7, 2017 Mine is pinned. Is this because I already had it pinned? I do see that when loaded another icon shows on the far right of the taskbar. Is this related?
Luke 42241 Posted June 7, 2017 Posted June 7, 2017 Mine is pinned. Is this because I already had it pinned? I do see that when loaded another icon shows on the far right of the taskbar. Is this related? It sounds like you aren't having a problem so I wouldn't worry about it. 1
shsharpe 0 Posted September 27, 2017 Author Posted September 27, 2017 Any progress with this issue? Thanks
shsharpe 0 Posted March 9, 2018 Author Posted March 9, 2018 Just wondering if there is any progress on this issue? Thanks!
GhostRider 49 Posted March 9, 2018 Posted March 9, 2018 (edited) Hi, What version of Emby Theater are you uisng? I do not see this with version 2.9.6 Edited March 9, 2018 by GhostRider
Guest Posted June 14, 2018 Posted June 14, 2018 New customer here, this is quite annoying, will it be fixed soon?
Luke 42241 Posted June 14, 2018 Posted June 14, 2018 It's unlikely to change right now due to some of the components used in the app. If you use the windows store version it won't have this issue, although the video player is not quite as good. Thanks.
Guest Posted June 14, 2018 Posted June 14, 2018 I'm afraid you'd need to pay me a significant amount of money to use the windows store.
Guest asrequested Posted June 14, 2018 Posted June 14, 2018 (edited) You can pin it, if you use the exe in the program folder. That's what I do. But the problem with that is when you launch, another icon pops up on the taskbar (that's electron with the Emby icon). When you close the app, it goes away, of course. Edited June 14, 2018 by Doofus 1
Guest Posted September 26, 2020 Posted September 26, 2020 Three years later and this is still an issue. You said a couple of years ago this was a known issue and you were going to fix this. Why isnt something as simple as this fixed? I find this to be completely unacceptable. I left Plex and even got a refund on my lifetime pass. I was gonna buy a lifetime pass from you guys but if you cant even fix simple things like this it doesnt instill any confidence that I should give you the hundred dollars. When is this going to be fixed? At this point we deserve an ETA? Period!
Guest Posted September 26, 2020 Posted September 26, 2020 (edited) delete me please Edited September 26, 2020 by Guest
Luke 42241 Posted September 26, 2020 Posted September 26, 2020 Hi, we are in process of reworking the app and that will resolve this. Thanks for the feedback.
