flexage 125 Posted June 10, 2017 Author Posted June 10, 2017 Ok the next problem is that it's not displaying my libraries when I click the button. Glad you got it installed! Are you saying that the install url on the github page worked, but the one at the top of this thread didn't? What kind of behaviour are you seeing when you try to enter a library? Are you seeing just an empty page? Or does it not even leave the home screen at all?
flexage 125 Posted June 10, 2017 Author Posted June 10, 2017 (edited) Update: It seems that, for now, using any skin other than default will most likely not work in the UWP/Windows Store version of Emby Theater Edit: Apparently there's a version of Emby Theater for the Xbox One? (I don't have one) I'm told it won't work on that either as it's based on the same platform Edited June 10, 2017 by flexage
Happy2Play 9811 Posted June 10, 2017 Posted June 10, 2017 Update: It seems that, for now, using any skin other than default will most likely not work in the UWP/Windows Store version of Emby Theater Edit: Apparently there's a version of Emby Theater for the Xbox One? (I don't have one) I'm told it won't work on that either as it's based on the same platform It appears tv.emby.media requires https address and desktop version it doesn't matter.
flexage 125 Posted June 10, 2017 Author Posted June 10, 2017 It appears tv.emby.media requires https address and desktop version it doesn't matter. Thanks! I'd noticed you'd discovered that in the other thread and I have made sure that any installation urls in the instructions and on the github for this skin have been updated to be https :thumbsup: 1
dredd1963 17 Posted June 10, 2017 Posted June 10, 2017 (edited) Basically the URL on at the top of this thread didn't work for me, but the github URL did work. When I click on the library I want it doesn't go to the library I selected be remains on the main page. The main page was showing only the menu on the left side and nothing else shown. I hope that the picture was of use to you mate. Edited June 10, 2017 by dredd1963
Luke 42242 Posted June 11, 2017 Posted June 11, 2017 tv.emby.media does not require https, just fyi. 1
Happy2Play 9811 Posted June 11, 2017 Posted June 11, 2017 (edited) tv.emby.media does not require https, just fyi. It required https in the plugin url for me or I get Installation Failure. But it apps the plugin installs but is non functional on TV.Emby.Media. Libraries but no Media. Edited June 11, 2017 by Happy2Play
Luke 42242 Posted June 11, 2017 Posted June 11, 2017 It required https in the plugin url for me of I get Installation Failure. But it apps the plugin installs but is non functional on TV.Emby.Media. Just tested with tv.emby.media over http, did not see any problems installing or utilizing the flexturary skin.
Happy2Play 9811 Posted June 11, 2017 Posted June 11, 2017 Just tested with tv.emby.media over http, did not see any problems installing or utilizing the flexturary skin. I get http install failure on multiple machines and browsers. And no media as shown in screenshot above.
Happy2Play 9811 Posted June 11, 2017 Posted June 11, 2017 Here's a pictures as it stands at mo! I can search and find media but I can't get libraries to display just like your image.
flexage 125 Posted June 11, 2017 Author Posted June 11, 2017 It required https in the plugin url for me or I get Installation Failure. But it apps the plugin installs but is non functional on TV.Emby.Media. Libraries but no Media. Here's a pictures as it stands at mo! Turns out there was an update today to Emby core with something I'd missed - I have just rolled out a new release (1.1.1) that fixes the missing libraries and related breakage. Just give ET a restart and you should be good to go
dredd1963 17 Posted June 11, 2017 Posted June 11, 2017 To be honest didnt think about searching for media. Just let message get stuck with the issue on the main page lol
Happy2Play 9811 Posted June 11, 2017 Posted June 11, 2017 Turns out there was an update today to Emby core with something I'd missed - I have just rolled out a new release (1.1.1) that fixes the missing libraries and related breakage. Just give ET a restart and you should be good to go Thought it may have been a cache issues as everything start working after clearing my cache, but no you made a change and it is working. 1
Happy2Play 9811 Posted June 11, 2017 Posted June 11, 2017 So the only version right now that doesn't work is "UWP/Windows Store version of Emby Theater". 2
yardameus 221 Posted June 11, 2017 Posted June 11, 2017 Great job so far! One note I have is that in the details page, the description font seems small and a little tough to read, but there is a lot of empty space. I thought either widening the description box and/or making the font bigger would be nice. Haven't run into any issues so far. Thanks for this. 1
Heuer 76 Posted June 11, 2017 Posted June 11, 2017 Seem to be getting formatting errors on some TV series screens: Loving it though!
yardameus 221 Posted June 11, 2017 Posted June 11, 2017 I also had a question, is it possible with skins to change the view (coverflow, list, etc...) or the sort order?
dredd1963 17 Posted June 11, 2017 Posted June 11, 2017 Am no expert but could the collection issue be a scrolling problem?
yardameus 221 Posted June 11, 2017 Posted June 11, 2017 He hasn't tried working on collections, doesn't even use them from what I gathered.
dredd1963 17 Posted June 12, 2017 Posted June 12, 2017 That's true, but wouldn't it be the case of the skin/ emby theatre reading the file marker and the page adjusting to what it's been told. But surely the theatre page coding come into play here. As I know nothing about coding am just clutching at straws here, so might be wrong.
buddyweiser 105 Posted June 13, 2017 Posted June 13, 2017 Flextuary An Emby Theater Skin Current Status This skin is currently still in development, and far from feature complete. Do you have a list of features you plan on implementing? A sort of road map? I would really like to see Scene Selection and Extras in the detail pages.
flexage 125 Posted June 13, 2017 Author Posted June 13, 2017 Great job so far! One note I have is that in the details page, the description font seems small and a little tough to read, but there is a lot of empty space. I thought either widening the description box and/or making the font bigger would be nice. Haven't run into any issues so far. Thanks for this. Thanks! I must admit that I haven't tested this on an actual TV screen yet, so the design has been based off legibility on my 27" inch PC monitors. I'll attempt to run it on a TV somehow (my boxes are all Shield & Fire TVs, so no ET I'm afraid) and see if I can tweak the font size. Seem to be getting formatting errors on some TV series screens: Loving it though! Cheers, I assume you're talking about the TV Show name, season number, episode number/title and clear art all being muddled up together at the top? I just need to get round to straightening that up a little bit and make sure it plays nicely with long titles I also had a question, is it possible with skins to change the view (coverflow, list, etc...) or the sort order? This should be possible, but could be fairly involved and take a bit of time - this is a free time project for me so can't promise anything quickly Am no expert but could the collection issue be a scrolling problem? The collection issue is simply because I haven't skinned that library view yet, I'm pretty sure it'll just be a case of applying the same treatment to this view as I already have to the other library views. I have set myself up with ebr's "Auto Boxsets" plugin so that I have a bunch of them ready to go
flexage 125 Posted June 13, 2017 Author Posted June 13, 2017 Do you have a list of features you plan on implementing? A sort of road map? I would really like to see Scene Selection and Extras in the detail pages. I don't have a list of planned features at this stage - I have a scribbled down list of small bugs and misc fixes that I've collected from user feedback on this thread, but short of the recent update which added a selection of Theme colors, and the UI sound packs, I didn't have anything else specific planned... I was thinking about making a feature request list on feathub (http://feathub.com/docs), so that I can gauge interest in the most popular feature requests, and target my efforts that way. Does that sound like something good to you guys?
flexage 125 Posted June 13, 2017 Author Posted June 13, 2017 Really nice. Wish I could do something like that. Just wondering, is there a way to get to the individual items in a collection, haven't spotted anything yet. Hey, support for collections/boxsets has been added - it could do with a little more spit and polish, but at least they work for now 1
