Wacind 1 Posted June 6, 2017 Posted June 6, 2017 (edited) Hi I am sorry if this is not the right place to ask for recommended settings but I'm looking for advice on what changes I can make to improve playback. I am using Emby mostly for Live TV. Here is my setup Emby server (v 3.2.19.0) on Win 7 - Connected via native tuner feature to HDHomerun Prime on local network. Both hooked to the router via Ethernet cables. - My ISP upload speed is 15Mbps Emby Home Theater (v 2.7.9) running on Win10 (not windows store app) on different network - ISP speed is 25Mbps download My objective is to minimize transcoding as i prefer not to tax my server.. I initially had all of my settings on Auto and I was getting Direct Play from my server however that causes my playback to freeze somewhat. More in the beginning of playback. I can circumvent this issue by simply pausing playback for 5 seconds and once i resume, my playback is smooth and never freezes. I noticed that this gives Emby HT enough buffer to run smoothly thereafter. In order to try avoid having to Pause, I tried playing around with the MBPS settings on Emby HT. At 25Mbps, I get Direct Play but encounter the above freezing issue. At 20Mbps, My server starts transcoding. I do not run into the above issue but because I want to avoid transcoding, this situation is not ideal either. So my question is... Is there anything else I can do to keep my MBPS setting at either 'Auto' or 25Mbps, therefore stay on Direct Play but also somehow avoid the intermittent freezing. Can i somehow add extra buffer or change any other settings? My hardware acceleration, all video and audio settings are untouched and set to 'Auto' Thanks Edited June 6, 2017 by Wacind
Luke 42243 Posted June 6, 2017 Posted June 6, 2017 It sounds like you've just reached the limit of what the network crossover can handle, is that right?
Wacind 1 Posted June 6, 2017 Author Posted June 6, 2017 Yep. that sounds like it. This happens only with Live TV. After switching to a channel, if I press pause for 5 or 6 seconds, it gives Emby HT enough time for the play timer to move up a bit and then once i resume, its smooth sailing there after. So for example when i begin playing, the play/end timer will almost be one for one. as in 0:04 /0:04. If i pause for a few seconds, this gives the HT some buffer time and once the timers are something like 0:04 / 0:09 then i can continue playing smoothly as both will keep incrementing there on onwards. This is happening only with the Live TV portion. I can Direct Play movies that are over 10GB in size without any issues.
Guest asrequested Posted June 6, 2017 Posted June 6, 2017 Are you using the windows store app or the app on the emby site?
Wacind 1 Posted June 6, 2017 Author Posted June 6, 2017 Are you using the windows store app or the app on the emby site? the regular app downloaded from the emby website.
Wacind 1 Posted June 6, 2017 Author Posted June 6, 2017 Well I've limited my HDHomerunPrime to only HD channels. At 20Mbps, they all Transcode. At 25Mbps, they all Direct Play The above freezing issue while Direct Playing is more noticeable in some channels than others. In order to avoid constant freezing I always tend to press Pause when switching to a new channel for about 5 or 6 seconds and then let it resume Sometimes the freezing does disappear on its own after about 30 minutes or so but sometimes it does not and pausing and resuming is the only solution. As Luke mentioned above, I am probably right at the limit so if i could somehow decrease the live tv file size by a little or add some sort of extra buffer I may be able to avoid having to pause and resume
Guest asrequested Posted June 6, 2017 Posted June 6, 2017 The reason I ask is because, with mine, some channels are MPEG2 and the rest are h264. I'm curious as to why either of those bitrates would force transcoding. The biggest stream I've seen in my programming was 10.5Mb/s. So at 20Mb/s you should have no problem. Can you post your transcode log?
Wacind 1 Posted June 6, 2017 Author Posted June 6, 2017 (edited) Thanks for the help so far Doofus! Similar to yours, some of my streams are MPEG2 and some are h264. Ive attached my logs. I restarted my server and ran my client on 25Mbps for the first 5 minutes or so. So that should be reflected in the server logs. I stopped playing at about 16:09 per the server logs I then changed the setting in Emby theater to 20Mbps and have attached the transcoding logs from that too. I started the transcoding stream at about 16:10 Both test runs were done on the same channel (CNBC which is an h264 channel) Thanks Edit: How would i find out what size / rate my streams are? Server.txt Transcoding.txt Edited June 6, 2017 by Wacind
Guest asrequested Posted June 6, 2017 Posted June 6, 2017 The easiest way to see what size the stream is, is to record a bit of it and look at its properties. I'll check your logs when I get home, later.
Wacind 1 Posted June 7, 2017 Author Posted June 7, 2017 So I recorded 20 mins of a tv episode and it was recorded using the "preserve origianal video and audio" settings checked. The overall bitrate was 13.3 Mbps of which the video was 12.6 Mbps
Guest asrequested Posted June 7, 2017 Posted June 7, 2017 So I recorded 20 mins of a tv episode and it was recorded using the "preserve origianal video and audio" settings checked. The overall bitrate was 13.3 Mbps of which the video was 12.6 Mbps So you should have more than enough bandwidth.
Guest asrequested Posted June 7, 2017 Posted June 7, 2017 You've got some weirdness when playing MPEG2 streams [mpeg2video @ 000000000049f500] Invalid frame dimensions 0x0. Last message repeated 7 times [mpegts @ 000000000032d9e0] Could not find codec parameters for stream 3 (Unknown: none ([134][0][0][0] / 0x0086)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/49b6ee912c0f4950a15b1956b548529d/stream.ts': Duration: N/A, start: 80470.275311, bitrate: N/A Program 51 Stream #0:0[0xddb]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 1920x1080 [SAR 1:1 DAR 16:9], Closed Captions, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1[0xddc]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, 5.1(side), fltp, 384 kb/s Stream #0:2[0xddd]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:3[0xdde]: Unknown: none ([134][0][0][0] / 0x0086) Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (copy) It's not supporting MPEG2. Are you sure you aren't inadvertently using the store app?
Guest asrequested Posted June 7, 2017 Posted June 7, 2017 (edited) @@Luke I noticed this. Possible issue? [mpegts @ 000000000032d9e0] Could not find codec parameters for stream 3 (Unknown: none ([134][0][0][0] / 0x0086)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Edited June 7, 2017 by Doofus
Wacind 1 Posted June 7, 2017 Author Posted June 7, 2017 Thanks Doofus. I definitely installed the regular windows installation (I'm not a fan of the win10 store apps) I can try reinstalling again tomorrow. Also since my upload speed is only 15Mbps, could that be why a 13.3Mbps stream might be struggling? That's pretty close isn't it?
Luke 42243 Posted June 7, 2017 Posted June 7, 2017 He's not on the store app. It's transcoding the video due to the bitrate setting. You'd have to pick something higher than 20mbps in order to have that direct play. If your upload speed is 15 I think a value around 12 is probably best.
Wacind 1 Posted June 7, 2017 Author Posted June 7, 2017 I see. So my options are either let it Direct Play and have to deal with freezing and pausing for a few seconds and resuming or option 2 is to transcode video which would tax my server a bit? Ok thanks. I'll look to see if I can check with my ISP to increase my upload speed
