JaseUK 0 Posted February 17, 2014 Posted February 17, 2014 (edited) Hi guys, Just wanted to know what the white tick in red box means on my dvd cover art. I am assuming its something to do with the fact I have watched the movies but i have watched other movies and it doesnt show a tick. In all honesty I dont really want the tick showing. Any help would be appreciated. Edited February 17, 2014 by JaseUK
Latchmor 584 Posted February 17, 2014 Posted February 17, 2014 Yip it means 'played' or watched. If you don't want it go to the MBC Config menu > View Options and untick 'Played Indicator on Items'. Cheers
JaseUK 0 Posted February 17, 2014 Author Posted February 17, 2014 Yip it means 'played' or watched. If you don't want it go to the MBC Config menu > View Options and untick 'Played Indicator on Items'. Cheers Yeah I've done this but the tick is still there. Using chocolate aswell if that helps
Latchmor 584 Posted February 17, 2014 Posted February 17, 2014 Strange, I'm using choc also and I can tick/untick that option and the ticks show/hide as soon as I come out of the config menu. Have you tried the other option also, 'Played indicator on Folders'? Not knowing your setup perhaps you need both of the Items/Folders options unticked? Cheers
Solution ebr 16333 Posted February 17, 2014 Solution Posted February 17, 2014 Chocolate has its own setting for Coverflow view. Under Chocolate Views. 1
Latchmor 584 Posted February 17, 2014 Posted February 17, 2014 Ha, you just beat me ebr, I never use coverflow but noticed it's own 'watched' indicator.
JaseUK 0 Posted February 17, 2014 Author Posted February 17, 2014 Brilliant thats sorted it. Thank you so much
AdrianW 1058 Posted February 18, 2014 Posted February 18, 2014 Turning off the watched indicator is fine for movies - but it would be a real pain for TV series, how are you going to know which episode you're up to? I wonder if anyone would find separate "show watched indicator" settings for movies and TV useful?
ebr 16333 Posted February 18, 2014 Posted February 18, 2014 Turning off the watched indicator is fine for movies - but it would be a real pain for TV series, how are you going to know which episode you're up to? I wonder if anyone would find separate "show watched indicator" settings for movies and TV useful? Most people view their episodes in some sort of list view and the list view has a different color for watched items.
