Froghut 3 Posted June 5, 2017 Posted June 5, 2017 Hi, When I play back certain video files and try to adjust the volume nothing happens, the volume stays the same even though I change the volume settings. Even when trying to change the volume in the Google Home app it still does not change at all. Here is the media info for one of the videos where that happens: VideoCodecH264AVCYesProfileHighLevel41Resolution1280x720Aspect ratio16:9AnamorphicNoInterlacedNoFramerate23.9760246Bitrate4615 kbpsBit depth8 bitPixel formatyuv420pRef frames1NAL4 AudioLanguageengCodecEAC3Layout5.1Channels6 chBitrate640 kbpsSample rate48000 HzDefaultYesTitleEng Dolby Digital+ 5.1 Default Container is mkv. 1
Luke 42243 Posted June 6, 2017 Posted June 6, 2017 @@Froghut is there an ffmpeg log? You can learn how to find that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/
Froghut 3 Posted June 6, 2017 Author Posted June 6, 2017 (edited) Here is the ffmpeg log: https://paste2.org/ImJJ7zch Edited June 6, 2017 by Froghut
Luke 42243 Posted June 6, 2017 Posted June 6, 2017 @@Froghut, we are using audio pass-through to send ac3 to your tv or receiver. when this happens you need to use the tv or receiver to control audio. That's why this happens with some files and not others. When audio passthrough is not used, like for aac or mp3 audio for example, then you'll be able to control with the Emby app. Does this make sense?
Froghut 3 Posted June 6, 2017 Author Posted June 6, 2017 Yes that makes sense, thanks for the explanation! But I have to say that is really not desirable for me, I would like to be able to always control the volume from within the emby app. Is there a way to force audio conversion as a "workaround" or something like that?
Froghut 3 Posted June 11, 2017 Author Posted June 11, 2017 *bump* Any plan to change this behaviour, or to add an option to force transcoding as a workaround?
Luke 42243 Posted June 12, 2017 Posted June 12, 2017 Ok I think I was actually wrong about this. I tested this with google home and I am not having any trouble changing volume when passing audio through directly to receiver.
Froghut 3 Posted June 13, 2017 Author Posted June 13, 2017 Is there any way I can help track down this issue? other log files or something?
Froghut 3 Posted June 13, 2017 Author Posted June 13, 2017 Tried it with the same video after restarting chromecast, but I still can't control the volume
Froghut 3 Posted June 17, 2017 Author Posted June 17, 2017 Just tried it with the new Android update, but it's still not working. Any news on this?
Luke 42243 Posted June 17, 2017 Posted June 17, 2017 I'm not able to reproduce but I am continuing to test this, thanks.
Froghut 3 Posted June 17, 2017 Author Posted June 17, 2017 If there is any way I can help like providing more logs, trying beta versions etc just let me know.
Luke 42243 Posted June 24, 2017 Posted June 24, 2017 @@Froghut, you said it only happens with some files, right? can you post more examples of some that do work and others that don't? We can use that information to try to see if there's a pattern to it. Thanks !
Froghut 3 Posted June 25, 2017 Author Posted June 25, 2017 I found quite a few older files (mostly 480p) that work: VideoCodec H264AVC YesProfile HighLevel 31Resolution 720x402Aspect ratio 16:9Anamorphic NoInterlaced NoFramerate 23.9760246Bitrate 904 kbpsBit depth 8 bitPixel format yuv420pRef frames 1NAL 4AudioCodec AACProfile LCLayout stereoChannels 2 chSample rate 48000 HzDefault YesTitle AAC stereo DefaultContainer mkv---VideoCodec MPEG4Codec tag XVIDProfile Advanced Simple ProfileLevel 5Resolution 624x352Aspect ratio 16:9Anamorphic NoInterlaced NoFramerate 23.9760246Bitrate 954 kbpsPixel format yuv420pRef frames 1AudioCodec MP3Layout stereoChannels 2 chBitrate 128 kbpsSample rate 48000 HzDefault NoTitle MP3 stereoContainer avi---VideoCodec H264Codec tag avc1AVC YesProfile HighLevel 31Resolution 720x404Aspect ratio 16:9Anamorphic NoInterlaced NoFramerate 23.9760246Bitrate 875 kbpsBit depth 8 bitPixel format yuv420pRef frames 1NAL 4AudioLanguage undCodec AACCodec tag mp4aProfile LCLayout stereoChannels 2 chBitrate 132 kbpsSample rate 48000 HzDefault YesTitle Und AAC stereo DefaultContainer mp4---VideoCodec H264AVC YesProfile MainLevel 31Resolution 1280x720Aspect ratio 16:9Anamorphic NoInterlaced NoFramerate 29.97003Bitrate 5000 kbpsBit depth 8 bitPixel format yuv420pRef frames 1NAL 4AudioLanguage engCodec AACProfile LCLayout stereoChannels 2 chBitrate 192 kbpsSample rate 44100 HzDefault YesTitle Eng AAC stereo DefaultContainer mkv And all files that don't work are newer files (mostly 720p) with the same Audio codec data: VideoCodec H264AVC YesProfile HighLevel 41Resolution 1280x716Aspect ratio 16:9Anamorphic NoInterlaced NoFramerate 23.9760246Bitrate 3212 kbpsBit depth 8 bitPixel format yuv420pRef frames 1NAL 4AudioCodec AC3Layout 5.1Channels 6 chBitrate 384 kbpsSample rate 48000 HzDefault YesTitle Dolby Digital 5.1 DefaultContainer mkv
Froghut 3 Posted June 25, 2017 Author Posted June 25, 2017 Yes, I checked a few more files, they are all ac3.
Luke 42243 Posted July 7, 2017 Posted July 7, 2017 I am planning on adding a setting to control ac3 passthrough behavior. thanks.
Froghut 3 Posted September 13, 2017 Author Posted September 13, 2017 Sorry for bringing this up again, but is there some kind of estimation on when this bug will be fixed? It is just really annoying to watch something on chromecast and not being able to control the volume of some content.
Froghut 3 Posted November 16, 2017 Author Posted November 16, 2017 This is still not working. I use my TV only for watching stuff via Chromecast and use my phone's IR to turn it on/off so I don't really use my TV remote at all, that's why it is really annoying that volume controm from inside the emby app is not working. In all other streaming apps (Netflix, Plex, etc) this works. I really want to love Emby but this is incredibly annoying.
Froghut 3 Posted January 6, 2018 Author Posted January 6, 2018 I just noticed Emby on Chromecast will now give a notice when volume control via Emby is not working. This is nice, but wouldn't it be possible when this is detected to instead force transcoding with an audio codec that supports volume control? If I force low quality on chromecast streaming it gets transcoded and no longer dirct streamed - and then volume control works. So instead just transcode with same video qulity but working audio?
Luke 42243 Posted January 6, 2018 Posted January 6, 2018 @@Froghut What notice do you mean? That's not coming from us. That must be something designed by Google.
Froghut 3 Posted January 7, 2018 Author Posted January 7, 2018 (edited) Oh, I guess it is a chromecast feature then, got a chromecast update a few days ago. I attached a picture I took. But anyway would it not be possible to force transcode on files with those audio codecs? Edited January 7, 2018 by Froghut
Luke 42243 Posted January 7, 2018 Posted January 7, 2018 it's possible but we currently don't have a setting for that. so it's something we'd have to look at adding. it is certainly not something we would do by default because most people would rather avoid the transcoding.
