b0mb 36 Posted June 5, 2017 Posted June 5, 2017 Hi! Because of heaving some trouble with Kodi on my FTVS i´ve installed latest SPMC build. I´ve also installed latest emby build from beta repo but after configuring it shows not a single emby playlist. I ust the addon mode. Any1 has an idea? Thx! b0mb
ebr 16337 Posted June 5, 2017 Posted June 5, 2017 Do your playlists show in the web app (using the same user)? Exactly what kind of playlists are they and exactly where are you looking for them?
b0mb 36 Posted June 5, 2017 Author Posted June 5, 2017 (edited) Do your playlists show in the web app (using the same user)? Exactly what kind of playlists are they and exactly where are you looking for them? The user accounts are OK. With Playlist I've meant the libraries. As another user also did not work using this fire TV stick I did a factory reset and try from scratch later. ;-) Looks like the problem belongs to the stick.. Gesendet von meinem Redmi Note 3 mit Tapatalk Edit: Fresh install and everything seems to be fine now [emoji6] Edited June 5, 2017 by b0mb
