PenkethBoy 2068 Posted June 21, 2017 Author Posted June 21, 2017 Having a couple of issues with .33 and 3.2.19.4 - again have tried on two different machines with very similar results. server-63632338245.txt When i go to the Episode Tab under my TV Library - Initially things look good with a quicker response to episode image generation than previously however as you move through the pages (of 100) Coverart crashes - see log - and you end up with a mix of rounded and square episode images - it does appear to recover if left for a few seconds but appears to fail on the "next" page or the one after that. Its almost as if coverart gets overwhelmed by having to do 100 images in one go - something the old version did not have a problem with although at the price of speed. Secondly i am seeing the same behavior when going into a Season - not sure if they are different images to those shown on the "Episode" tab or newly generated Thirdly i am seeing artifacts at the corners for some of the rounded images - e.g at the top of S02E10,16,17 - not the end of the world but unsightly Hopefully these are just teething problems Happy to test any fixes etc as necessary Please try it and report your experience. Thanks ! @@Luke - as above on .34 - treatments are leaving "artifacts" around the corners etc as explained above
PenkethBoy 2068 Posted June 21, 2017 Author Posted June 21, 2017 .35 and 20.7 boxsets treatment not working for me either also still seeing artifacts at corners - .35 did not appear to cause a rebuild of images like it usually does for a new version - so these are probably "old" treatments
Luke 42252 Posted June 21, 2017 Posted June 21, 2017 Config screen should be resolved with server 3.2.20.8
PenkethBoy 2068 Posted June 21, 2017 Author Posted June 21, 2017 Boxsets are working for me now with the server update - thanks Any news on the "artifacts" ?
Happy2Play 9814 Posted June 21, 2017 Posted June 21, 2017 (edited) Preview is working but still seeing partial disc on right. And I manually deleted images folder and cleared browser cache. clearcase discs diamond discs Edited June 21, 2017 by Happy2Play
