drikosv8 25 Posted June 4, 2017 Posted June 4, 2017 (edited) I am having problems with the iptv audio using Ember's native application. It happens that when watching some channels of any platform by google chrome the audio gets robotized. In order to test and see if the channel was in trouble, I also watched Kodi and all the channels that had problems with the emby, they have the perfect audio in the kodi. I'm waiting and once again thank you very much. Estou com problemas no audio do iptv usando a aplicação nativa do Ember. Acontece que ao assistir alguns canais de qualquer plataforma pelo google chrome o audio fica robotizado. Para poder testar e ver se o canal estava com problemas assisti tambem no Kodi e todos os canais que estavam com problemas no emby, estão com o audio perfeito no kodi. Fico no aguardo e mais uma vez muito obrigado Log.txt Edited June 4, 2017 by drikosv8
Luke 42243 Posted June 5, 2017 Posted June 5, 2017 @@drikosv8 you're saying this happens in the web app using Chrome? Can you give me a copy of your m3u so that I can test it myself? you can PM it to me. thanks !
drikosv8 25 Posted June 6, 2017 Author Posted June 6, 2017 @@Luke I already sent you via MP Luke the .m3u file. I await your analysis, my friend. Thank you @@Luke Já te enviei via MP Luke o arquivo .m3u. Aguardo sua analise amigo. Obrigado
Luke 42243 Posted June 6, 2017 Posted June 6, 2017 I tested and the problem is in the browser. Those channels have very low bitrate stereo audio and the browser is just not playing them very well. The only solution would be to force server transcoding, which we don't currently have a setting for but we can look at for a future update. thanks.
drikosv8 25 Posted June 6, 2017 Author Posted June 6, 2017 @@Luke, Okay, thanks Luke, I'll wait for the update. By Google chrome of the android phone, even changing the bitrate configuration to transcode, the audio continues robotized. More will await the update. Thank you one more time. 3 things that I am very much looking forward to in future updates are: 1st DLNA Remote 2nd Limit connection number per User 3º Audio IPTV robotizando via google chrome I hope she will soon be friends, it will make all the difference. Thank you for always being present in the solutions. @@Luke, Ok, Obrigado Luke, aguardarei a atualização. Pelo Google chrome do Celular android, mesmo mudando a configuração bitrate para transcodificar, o áudio continua robotizado. Mais aguardarei a atualização. Mais uma vez muito obrigado. 3 coisas que estou muito ansioso para que venha nas futuras atualizações são: 1º DLNA Remoto 2º Limitar numero de conexão por Usuário 3º Áudio IPTV robotizando via google chrome Espero que ela venham logo amigo, irá fazer toda a diferença. Muito obrigado por sempre estar presente nas soluções.
Luke 42243 Posted June 6, 2017 Posted June 6, 2017 The audio on the tv stream is really bad. the sample rate is very uncommon - 11025. if you have the ability you should ask your provider to improve that.
drikosv8 25 Posted June 7, 2017 Author Posted June 7, 2017 (edited) @@Luke Unfortunately it is not possible to see with the provider, because here in Brazil, we get the internet channel links, through blog sharing and sites that make .m3u files available for download. @@Luke Infelizmente não é possível ver com o provedor, pois aqui no Brasil, pegamos os link de canais da internet, através de compartilhamento em blog e sites que disponibilizam os arquivos .m3u para ser baixado. Edited June 7, 2017 by drikosv8
