eric859 1 Posted June 3, 2017 Posted June 3, 2017 I removed a m3u tuner and the channels aren't being removed from the channel listing in the app. Not sure how to manually refresh the channel listing from the server. Any ideas? Thanks!
maegibbons 1287 Posted June 3, 2017 Posted June 3, 2017 If that suggestion does not work. Go in to the m3u tuner and re-save the file already entered. We have found that a guide refresh does not always re-read the m3u list. Or at least it didnt a few releases ago - have not tested that recently. Krs Mark
Luke 42243 Posted June 3, 2017 Posted June 3, 2017 The end result of those two actions is the same. Why do you think that it doesn't re-read the list?
eric859 1 Posted June 4, 2017 Author Posted June 4, 2017 (edited) How long does a Refresh Guide usually take? It's just sitting there at 33.3% for like 30 minutes. Actually, when I refresh the dashboard, it shows as 0.0%. Great, it went down. Edited June 4, 2017 by eric859
maegibbons 1287 Posted June 4, 2017 Posted June 4, 2017 The end result of those two actions is the same. Why do you think that it doesn't re-read the list? From MUCH imperical testing in January when setting up my m3u list. As specified i HAVE NOT TESTED THIS RECENTLY and the original issue may have been fixed. Krs Mark
Luke 42243 Posted June 4, 2017 Posted June 4, 2017 How long does a Refresh Guide usually take? It's just sitting there at 33.3% for like 30 minutes. Actually, when I refresh the dashboard, it shows as 0.0%. Great, it went down. @@eric859 if there are a lot of changes then it may take a little longer than usual. it depends on the number of channels that you have.
Luke 42243 Posted June 4, 2017 Posted June 4, 2017 From MUCH imperical testing in January when setting up my m3u list. As specified i HAVE NOT TESTED THIS RECENTLY and the original issue may have been fixed. Krs Mark Thanks for the info. I don't think this is an issue anymore.
eric859 1 Posted June 4, 2017 Author Posted June 4, 2017 Something got screwed up. Refresh guide wasn't working at all. I would just hang. I ended up deleting all tuners and restarting my live tv setup from scratch. Works now. Thanks!
