tdiguy 99 Posted June 20, 2017 Posted June 20, 2017 Yes @@tdiguy, OSMC is on a microsd and the media is on a external drive. Do you need any information about the SD? Tks No I am just being nosy. I kind of wonder if it is likely related to the read / write speed of the sd card. I say this because i run emby off my pi but nearly never run into this issue, but i run my pi off an external hard drive. I read all sorts of people complaining about the microsd card going corrupt on them seemingly randomly.
tdiguy 99 Posted June 21, 2017 Posted June 21, 2017 I notice the final log entries are related to image collage creation. I think for the next release what we'll do is just disable this for arm cpu's going forward. I hate to ask but could you make it optional? I kinda like it and havent found good replacement icons.
karaskis 0 Posted July 3, 2017 Author Posted July 3, 2017 (edited) I notice the final log entries are related to image collage creation. I think for the next release what we'll do is just disable this for arm cpu's going forward. @@Luke, Just updated to release 3.2.22.0 and ran a library scan on my movie folder with the "Download artwork and metadata from the internet" and "Save artwork and metadata into media folders" disabled. It successfully added all my movies to the library. Then I enabled those 2 options and added my TV folder as new media and hit library scan. As result my pi crashed, same erros as before. I'm I doing anything wrong?? Log attached. 2017-07-03 20:22:03.0157 Info HttpClient: Checking for cache file /config/cache/httpclient/f70ca6622474da8168a3b6c06f651a162017-07-03 20:22:03.0760 Info HttpServer: HTTP Response 200 to 192.168.100.5. Time: 66ms. http://192.168.100.3:8096/emby/Packages/Updates?PackageType=System 2017-07-03 20:22:03.2076 Info HttpServer: HTTP Response 200 to 192.168.100.5. Time: 204ms. http://192.168.100.3:8096/emby/Packages/Updates?PackageType=UserInstalled ������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������� Log7.txt Edited July 3, 2017 by karaskis
Luke 42245 Posted July 5, 2017 Posted July 5, 2017 @@karaskis, I'm going to ask you to expirement here. Can you please go to: /usr/lib/emby-server/bin You'll see a file called ImageMagickSharp.dll.config. Delete that file for now (make sure to back it up), then startup the server and see how that compares. thanks.
karaskis 0 Posted July 11, 2017 Author Posted July 11, 2017 @@karaskis, I'm going to ask you to expirement here. Can you please go to: /usr/lib/emby-server/bin You'll see a file called ImageMagickSharp.dll.config. Delete that file for now (make sure to back it up), then startup the server and see how that compares. thanks. @@Luke, no problem in experimenting. I'm running on version 3.2.25.0 and installed emby-server using docker official instructions: https://emby.media/community/index.php?/topic/43166-arm-devices-official-instructions/ Recommend install method for armhf/armv7 (Tested rpi2/3 running rasbian): curl -sSL https://get.docker.com/ | sh docker run -it --rm \ --volume /usr/local/bin:/target \ emby/embyserver:armv7 instl /usr/lib/emby-server/bin is not available (see attached file). I also tried searching by SSH command the file ImageMagickSharp.dll.config but found nothing. Can the location or file name vary? Tried running a scan again and got the same error. Log8.txt
karaskis 0 Posted July 29, 2017 Author Posted July 29, 2017 @@Luke, I haven't given up yet.. Emby server continues to crash and freeze Pi3 on library scans. Clearly it's having difficulty on scanning a large number of files. I've added an empty "TV" folder to my scan directory. Then one at a time throu SSH I added (cut/paste) show folders containing several seasons and episodes. Then back on emby ran library scan (log9 and 10 attached).The scan crashed pi3 when it had scanned half of the new content. I unplug pi and restart the server and ran a new scan with the exact same content (did not add or remove any files) and the scan was successful (log11). After the successful scan added new content to folder and hit scan. Server crashed again just after getting the "New content notification" on Chrome (log 12 attached). This was the exact same step when server crashed on log9. Can't the notifications be freezing the server? Please help!! 2017-07-29 09:39:57.2332 Info HttpServer: HTTP Response 304 to 192.168.100.5. Time: 3ms. http://192.168.100.3:8096/web/bower_components/emby-webcomponents/notifications/badge.png2017-07-29 09:39:57.2332 Info HttpServer: HTTP Response 304 to 192.168.100.5. Time: 3ms. http://192.168.100.3:8096/web/bower_components/emby-webcomponents/notifications/notificationicon.png Log12.txt Log11.txt Log10.txt Log9.txt
Luke 42245 Posted August 17, 2017 Posted August 17, 2017 @@karaskis please try the latest release of Emby server. thanks !
karaskis 0 Posted August 31, 2017 Author Posted August 31, 2017 @@karaskis please try the latest release of Emby server. thanks ! OMG @@Luke it worked! I could scan my entire library and it did not crash! I'll run some more tests over the weekend and post the results. Thank you so much.
Luke 42245 Posted September 1, 2017 Posted September 1, 2017 Thanks for the feedback. You might also be interested in testing Emby Server for .NET Core, since .NET core performs better than mono with a smaller footprint: https://emby.media/community/index.php?/topic/50012-emby-server-for-net-core/
2Fake 0 Posted September 7, 2017 Posted September 7, 2017 Hi. I facing the exactly same issue that during the scan of my library after a few minutes my rpi3 freezes. Which files do you need to debug? Regards 2fake
Luke 42245 Posted September 9, 2017 Posted September 9, 2017 @@2Fake, can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ thanks.
2Fake 0 Posted September 11, 2017 Posted September 11, 2017 hi, i installed everything again, because i tried the dotnet core build, but i didn't worked for me as you know now the library scan is running since 15 minutes. Normally my rpi crashed in this time. I will keep you up to date if it crashes again. 2Fake
2Fake 0 Posted September 11, 2017 Posted September 11, 2017 Hi again, i was too fast with my post i just crashes two minutes after my post. You will find my logfile in the attachment. 2Fake server-63640714637.txt
2Fake 0 Posted September 11, 2017 Posted September 11, 2017 It's getting more weird i installed the beta from the repository and now emby is not able to start the webUI but the library scan is running since a hour now server-63640723643.txt
2Fake 0 Posted September 11, 2017 Posted September 11, 2017 (edited) hi, it's me again. Does this line mean that everything is ok '2017-09-11 14:17:09.439 Info TaskManager: Scan media library Completed after 208 minute(s) and 31 seconds' now my only problem is that i don't have a UI I attached a logfile from the server startup, but i still don't have an UI server-63640736684.txt Edited September 11, 2017 by 2Fake
Luke 42245 Posted September 11, 2017 Posted September 11, 2017 Try going here: /var/lib/emby-server/plugins and removing all plugin .dll files. Thanks.
2Fake 0 Posted September 11, 2017 Posted September 11, 2017 Hi. Still no UI after deleting the *.dll Here is the log with debug information enabled server-63640757475.txt
2Fake 0 Posted September 11, 2017 Posted September 11, 2017 Emby doesn't open the port. So I can't connect via browser to emby
2Fake 0 Posted September 11, 2017 Posted September 11, 2017 It's working now. Don't know what changed but everything is OK now. Thank you Gesendet von meinem SM-G935F mit Tapatalk
karaskis 0 Posted September 16, 2017 Author Posted September 16, 2017 It's working now. Don't know what changed but everything is OK now. Thank you Gesendet von meinem SM-G935F mit Tapatalk @@2Fake, are you using the dotnet core build? How did you install it? Tks
2Fake 0 Posted September 18, 2017 Posted September 18, 2017 @@karaskis i tried to, but i got always a memory access failure. Now i'm running the emby beta server which works fine.
