CharleyVarrick 284 Posted June 3, 2017 Posted June 3, 2017 (edited) Fellow Emby enthusiasts, what device(s) are you using to control your htpc? Full names and picture if possible. It can be any of those: 1) separate k/bd and mouse 2) all in one (w/trackpad or trackball) 3) remote control 4) smartphone/tablet with app "?" 5) voice recognition 6) telekynesis 7) other? Myself, I presently use a Logitech Mediaboard PS3 bluetooth + a Logitech Harmony Ultimate One remote. Edited June 5, 2017 by jlr19
BAlGaInTl 288 Posted June 5, 2017 Posted June 5, 2017 I use a Nvidia Shield now, but have done a full HTPC in the past. I use a Logitech K830, Harmony Hub and Simple Remote, and a Google Home (voice commands). + + I started out with a Logitech K400 for the Keyboard/Mouse, but MUCH prefer the K830 for the backlit keys, rechargeable battery, and significantly better touchpad. I also prefer the simple remote over the ones with screens. I've been using it for a couple of years now and still haven't had to replace the battery.
CharleyVarrick 284 Posted June 5, 2017 Author Posted June 5, 2017 I also prefer the simple remote over the ones with screens. I've been using it for a couple of years now and still haven't had to replace the battery. The Harmony Ultimate One is rechargeable (and comes with base) But I know what you mean, this little screen is power hungry.
BAlGaInTl 288 Posted June 5, 2017 Posted June 5, 2017 The Harmony Ultimate One is rechargeable (and comes with base) But I know what you mean, this little screen is power hungry. I had an older one with a screen/base. Pre-hub. I forget the exact model, but it seemed that screen was of minimal use to me. I only used it to start activities (which are hard buttons on the simple remote). The cool thing about the hub is that if I need a screen or other functions I haven't mapped, I can always break out the app on my phone.
