ebr 16335 Posted June 3, 2017 Posted June 3, 2017 Hi. Is this any different in the web app? How many episodes exist in what you are shuffling? How many times did you try before you decided it was "always"?
Farfignugget 4 Posted June 4, 2017 Author Posted June 4, 2017 Hi. I haven't tried web app, but i will tomorrow. The number of episodes varies from 10 to 200 I just tried 20+ times on 15 different series. First episode, always.
Farfignugget 4 Posted June 4, 2017 Author Posted June 4, 2017 If it helps narrow it down, it was working fine about 10 days ago
Luke 42242 Posted June 4, 2017 Posted June 4, 2017 If you advance to the next, does it play episode two , or something else?
Farfignugget 4 Posted June 4, 2017 Author Posted June 4, 2017 Yes, i checked three different series. They are playing them in order starting at episode 1.
Farfignugget 4 Posted June 11, 2017 Author Posted June 11, 2017 Updated to beta server 3.2.19.8. Shuffle play is still playing episodes in order starting at the first one of the series.
