aptalca 71 Posted June 1, 2017 Posted June 1, 2017 I realize that the UWP's TV interface is completely different than the Desktop and the mobile/tablet interfaces. I really like the latter. (It seems one is the same as tv.emby.media and the other app.emby.media) However, I noticed that in the desktop or mobile interfaces, there are a couple of bugs. 1) Hitting "Downloads" on the dashboard goes to an empty list with a forever spinner in the middle. Items never load (In the TV interface, it shows the movie and tv sections correctly). 2) Hitting the "More" buttons next to the Next Up, Latest Movies and Latest Shows results in an all white screen and the app becomes unresponsive. Thanks
Luke 42243 Posted June 1, 2017 Posted June 1, 2017 Hi, I'll test downloads but the more buttons are working fine for me. Are you sure you tested recently? thanks.
Solution Luke 42243 Posted June 1, 2017 Solution Posted June 1, 2017 The Downloads issue is resolved for the next update, thanks. 1
aptalca 71 Posted June 1, 2017 Author Posted June 1, 2017 (edited) Hi, I'll test downloads but the more buttons are working fine for me. Are you sure you tested recently? thanks. This is with the latest from the store (version 1.1.126.0): Edited June 1, 2017 by aptalca
aptalca 71 Posted June 2, 2017 Author Posted June 2, 2017 Just downloaded the new update and both issues are fixed :-) Thanks so much
