pju 10 Posted June 1, 2017 Posted June 1, 2017 Chapter etraction has stopped working some time ago. I haven't noticed since the task runs without errors - although a bit fast. The chapters do not show in neither browser nor in EMC. And I have no idea where to start looking... The server log isn't helping me. server-63631925295.txt
Solution FrostByte 5436 Posted June 1, 2017 Solution Posted June 1, 2017 Chapter extraction is working for me. Awhile back they changed to a per library type setting. Is the option selected for each type (Movies, TV, etc) which you want? Settings, Library, then click on media type 1
ebr 16309 Posted June 1, 2017 Posted June 1, 2017 @@pju please let us know if this solved your issue. Thanks.
pju 10 Posted June 1, 2017 Author Posted June 1, 2017 Embarrassing! @FrostByte: Thanks a lot - you were spot on. The catch-up to about 3 hrs and ran without problems. Maybe I should take a day off to discover all the config options in Emby Great product. 1
