mwkurt 5 Posted May 30, 2017 Posted May 30, 2017 (edited) Hello, I am not sure whether this is an Emby problem, a Kodi problem or something else entirely. I am hoping that some here can lead me in the proper direction. Over the past 2 or three days, playback of local video files will stop for no apparent reason whatsoever. This appears to be happening on just my Nvidia Shield devices. I am able to start playback immediately. For those that could help, here is a log file where this has happened twice. https://www.dropbox.com/s/q0u5fbex2xomg1m/server-63631699200.txt?dl=0 There are a lot of "error creating port map" problems though I am not sure if those have anything to do with my problem. The problem happens here: 2017-05-30 00:48:28.8926 Info HttpServer: HTTP POST http://192.168.1.11:8096/emby/Sessions/Playing/Stopped. UserAgent:2017-05-30 00:48:28.9082 Info SessionManager: Playback stopped reported by app Kodi 2.3.48 playing Sins of Commission. Stopped at 1095462 ms2017-05-30 00:48:28.9082 Info HttpServer: HTTP Response 204 to 192.168.1.3. Time: 16ms. http://192.168.1.11:8096/emby/Sessions/Playing/Stopped and here: 2017-05-30 06:19:39.8942 Info HttpServer: HTTP Response 200 to 192.168.1.18. Time: 0ms. http://192.168.1.11:8096/emby/Emby.Kodi.SyncQueue/GetServerDateTime?format=json2017-05-30 06:20:05.5718 Info HttpServer: HTTP POST http://192.168.1.11:8096/emby/Sessions/Playing/Stopped. UserAgent:2017-05-30 06:20:05.5718 Info SessionManager: Playback stopped reported by app Kodi 2.3.48 playing Yankee White. Stopped at 2656614 ms2017-05-30 06:20:05.5874 Info HttpServer: HTTP Response 204 to 192.168.1.6. Time: 16ms. http://192.168.1.11:8096/emby/Sessions/Playing/Stopped Any help would be greatly appreciated. Thanks, Mark Edited May 30, 2017 by mwkurt
Luke 42241 Posted May 30, 2017 Posted May 30, 2017 Can you provide the emby for kodi log as well? thanks.
mwkurt 5 Posted May 31, 2017 Author Posted May 31, 2017 Hello, Yes I will....I have determined that it happens at the same time every day, 6.5 hours apart. This is strange!
Luke 42241 Posted May 31, 2017 Posted May 31, 2017 Try removing the kodi sync plugin and see if the issue persists. thanks.
