ywecur 0 Posted May 30, 2017 Posted May 30, 2017 When I invite someone to my server and they link their emby connect account the password from their emby connect isn't the same as the one on the server. In fact, if they set no password on the server ANYONE can log into their account without any password and access all media on the server! Is this expected behavior? Seems completely insane to me! Why do I have to set passwords for users who already have passwords for their emby connect accounts? Is there a way to disable login without access to their emby connect account?
Happy2Play 9802 Posted May 30, 2017 Posted May 30, 2017 (edited) Well you could disable their User account so they only have access with their guest account. Why are you inviting and making User accounts? Edited May 30, 2017 by Happy2Play
ywecur 0 Posted May 30, 2017 Author Posted May 30, 2017 Well you could disable their User account so they only have access with their guest account. Why are you inviting and making User accounts? OK, maybe I'm completely mistaken here. I want my friends to be able to watch my media. What's the prefered way to do that? Right now I needed to create accounts for them
Solution Luke 42200 Posted May 30, 2017 Solution Posted May 30, 2017 if you use the Guest process in emby server dashboard, then they cannot login locally and must use their Emby Connect credentials (which yes, always have a password). However - if you first create a local Emby user, and then after you link that to an Emby Connect user, then either login method is possible. it sounds like you want to use the guest feature. 1
ywecur 0 Posted May 30, 2017 Author Posted May 30, 2017 That was it. Thank you, and excuse my ignorance
