tdiguy 99 Posted May 29, 2017 Posted May 29, 2017 I am not sure where this is coming from but i am now getting the following error: Refresh Guide failed.a minute ago Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. This was working at least the first time i re-installed everything from OS to emby server since the first update though it started throwing this error. The guide xml file is being updated with the script and cron job. I will attach the log and the guide xml file some advice on this is greatly appreciated. xmltv.xml server-log.txt
Solution Luke 42245 Posted May 29, 2017 Solution Posted May 29, 2017 Your library.db file has become corrupt somehow. This generally happens due to a sudden abrupt termination of the server process, like a power failure or other kind of sudden shutdown. You will need to shutdown the server, then rename this file: /var/lib/emby-server/data/library.db Then start back up and run a library scan + guide refresh. 1
tdiguy 99 Posted May 29, 2017 Author Posted May 29, 2017 Perfect, thank you that hit the nail on the head. 1
