spyderelcd 0 Posted May 29, 2017 Posted May 29, 2017 (edited) My Roku works great with the new app. The only problem I'm having is when you go to live tv and pull the guide up. When you press the down arrow it skips one channel every time you press it. So it's impossible for me to watch some channels on the roku cause skips right by it. Everything else works good when I press play it goes right to the stream, when i press fast forward it goes to the next screen in the guide also. Is there something somebody can do to help me? I have attached a log also Thanks Log.txt Edited May 29, 2017 by spyderelcd
AmericanMike 18 Posted May 29, 2017 Posted May 29, 2017 I have the same issue with my Roku 2 only. Works fine with my Roku 3. I try quicker presses on the Roku 2 to get around it. A bit tricky but doable.
ebr 16335 Posted May 29, 2017 Posted May 29, 2017 Yeah, I think firmware updates have changed behavior here a bit. We are having to handle auto repeat on holding the key down ourselves and the timing can be tricky. I'll try increasing the amount of time you have to hold the button down. In the meantime, if you are quick and deliberate about your presses, it should work properly. 1
