marco1475 0 Posted May 29, 2017 Posted May 29, 2017 Hi, I just set up Emby 3.2.17.0 and Kodi 17.3-1, using the Emby for Kodi plugin 2.3.48. All of my Emby libraries are present in Kodi as tags (i.e. all of their files are tagged with the Emby library name), except for the library named "Trailers". There is not tag "Trailers" anywhere in Kodi and none of the library files are present as well. The "Trailers" library is marked as "mixed content", but so are two or three of my other Emby libraries and they made it as tags into Kodi. I tried re-creating the Kodi database to no avail. When I connect directly to Emby (via web or smartphone app) I can see all my libraries, including "Trailers", and play all the files in them without issue. Is there anything special about the name "Trailers" either in Emby or Kodi that would prevent the files from showing up / being tagged with the Emby library name in Kodi? Any ideas what I could try to get my trailers to show up in Kodi, properly tagged? Thanks, Marek
Angelblue05 4132 Posted May 29, 2017 Posted May 29, 2017 I'll have to test. I don't believe there's something special about it.
