mitomac 0 Posted May 28, 2017 Posted May 28, 2017 (edited) Greetings, I'm using schedule-direct json to pull in guide information including channel icons. All is working fine, expect that many of the icons are black on a transparent background. Thus, in the default theme it near impossible to see the channel icons (in the leftmost guide column or even on the cards in the 'channels' section. I've played around with the css -- but having trouble pinpointing the exact parameters I need. For example, I can see that the left most guide column is '#2d2d2d' and I would like to lighten it to '#888888', but darn if I can figure out the correct css class. Many thanks! Mitomac Edited May 28, 2017 by mitomac
pir8radio 1313 Posted May 28, 2017 Posted May 28, 2017 Have not tested, but have you tried button.channelHeaderCell { color settings here; }
mitomac 0 Posted May 28, 2017 Author Posted May 28, 2017 Perfect ! button.channelHeaderCell { background-color: #777777 } works like a charm. Cheers, mitomac
