chef 3811 Posted June 1, 2017 Posted June 1, 2017 (edited) I know the server chassis I have right now a full ATX by cooler master has been great. I bought a really quite and big CPU fan. the CPU temps are around 32 when transcoding which is good I think. These mini ATX cases might not have been a good choice, not sure until they arrive. There won't be any GPU stuff happening so hopefully I can fit at least 4 drives in there. I haven't ever built a rig with FreeNAS, apparently from what I read it runs on a thumb drive. Edited June 1, 2017 by chef
Jdiesel 1435 Posted June 1, 2017 Posted June 1, 2017 I know the server chassis I have right now a full ATX by cooler master has been great. I bought a really quite and big CPU fan. the CPU temps are around 32 when transcoding which is good I think. These mini ATX cases might not have been a good choice, not sure until they arrive. There won't be any GPU stuff happening so hopefully I can fit at least 4 drives in there. I haven't ever built a rig with FreeNAS, apparently from what I read it runs on a thumb drive. I recommend grabbing one of these for you OS thumbdrive. Beats having a drive sticking out the back of your case that is asking to get bumped or removed by accident. https://www.startech.com/ca/Cables/USB-2.0/Internal-and-Panel-Mount/6-USB-A-Female-to-Motherboard-Header-Adapter~USBMBADAPT 2
CharleyVarrick 284 Posted June 1, 2017 Author Posted June 1, 2017 (edited) I recommend grabbing one of these for you OS thumbdrive. Beats having a drive sticking out the back of your case that is asking to get bumped or removed by accident. https://www.startech.com/ca/Cables/USB-2.0/Internal-and-Panel-Mount/6-USB-A-Female-to-Motherboard-Header-Adapter~USBMBADAPT That's one smart little device right there. On my ex-ex htpc (the ThermalTake Bach), I had one of those usb rf module-thing (similar looking to a thumbdrive) but for rf transmission to my htpc keyboard, and it was sticking out right in front. Not just ugly, but someone walked by a little too close and bent the thing out of wack. Nowadays those usb gizmos have become real small. It also reminds me of the first wireless keyboard I got from M$ (13 or 14 years ago), the rf receiver was bigger than a hockey puck, and had a range of about 2 feet. Needless to say it was the first and last M$ hardware I ever bought. Edited June 1, 2017 by jlr19 1
Jdiesel 1435 Posted June 1, 2017 Posted June 1, 2017 That's one smart little device right there. On my ex-ex htpc (the ThermalTake Bach), I had one of those usb rf module-thing (similar looking to a thumbdrive) but for rf transmission to my htpc keyboard, and it was sticking out right in front. Not just ugly, but someone walked by a little too close and bent the thing out of wack. Nowadays those usb gizmos have become real small. It reminds me also of the first wireless keyboard I got from M$ (13 or 14 years ago), the rf receiver was bigger than a hockey puck, and had a range of about 2 feet. Needless to say it was the first and last M$ hardware I ever bought. That is true, thumb drives have gotten very small these days to the point where some sick out just far enough to get a grip on it to remove from the USB port.
CharleyVarrick 284 Posted June 1, 2017 Author Posted June 1, 2017 Had one of those smallish one, can't remember the brand, I pulled it out and only the "grip" came out, the business part stayed in the usb port. GRRR!
mediacowboy 438 Posted June 1, 2017 Posted June 1, 2017 @@CBers, another idea before you destroy case would be these. Nexus DoubleTwin Hard Drive Vibration Absorber https://www.amazon.com/dp/B001AZHS04/ref=cm_sw_r_cp_apa_tjemzb24EKWA3 I see in the case the hard drive mount from the bottom and those will allow you to mount a hard drive on top. I have used these before as well in my first media server. 1
CharleyVarrick 284 Posted June 1, 2017 Author Posted June 1, 2017 (edited) @@CBers, another idea before you destroy case would be these. Nexus DoubleTwin Hard Drive Vibration Absorber https://www.amazon.com/dp/B001AZHS04/ref=cm_sw_r_cp_apa_tjemzb24EKWA3 I see in the case the hard drive mount from the bottom and those will allow you to mount a hard drive on top. I have used these before as well in my first media server. I think you meant this for @@chef instead of CBers. I can't seem to wrap my head with how you use those things, EDIT: This helps to picture them, somehow Edited June 1, 2017 by jlr19
mediacowboy 438 Posted June 1, 2017 Posted June 1, 2017 (edited) Yep. Sorry. Flip the bottom drive over and then screw in the to the bottom screw holes to the mounting points. Edited June 1, 2017 by mediacowboy 1
Guest asrequested Posted June 3, 2017 Posted June 3, 2017 Great! Thanks I just Doofus (ordered) a pair of those. Thanks again Poor @ , he keeps getting picked on just because he strives to build the perfect emby server. Well when he buys something new every other day. Stay tuned!
CharleyVarrick 284 Posted June 3, 2017 Author Posted June 3, 2017 I am scared now, ever since I saw this humongous desktop video... Doofus, DON'T!!!
