Luke 42200 Posted May 31, 2017 Posted May 31, 2017 Probably not because it looked like a lot of it was caused by plugins, but let us know. thanks.
Sammy 790 Posted June 1, 2017 Author Posted June 1, 2017 @@Luke Even though you didn't intend to fix this issue it is fixed. Whether this update did it or it is something else, IDK, but my CPU usage by Emby Server is now down below 5 and typically sitting at 0 when idle.
ebr 16309 Posted June 1, 2017 Posted June 1, 2017 More than likely, whatever needed to be done got done.
carloscabral 0 Posted June 2, 2017 Posted June 2, 2017 USE SOMENTE FILMES EM .MP4 NÃO USE .MKV, EM .MP4 O SOFTWARE NÃO FAZ A CONVERSÃO JÁ EM MKV ABRE SE VARIOS PROCESSOS PARA CONVERTER A MÍDIA ASSIM PESANDO O SISTEMA
Luke 42200 Posted June 3, 2017 Posted June 3, 2017 USE SOMENTE FILMES EM .MP4 NÃO USE .MKV, EM .MP4 O SOFTWARE NÃO FAZ A CONVERSÃO JÁ EM MKV ABRE SE VARIOS PROCESSOS PARA CONVERTER A MÍDIA ASSIM PESANDO O SISTEMA Obrigado pelo conselho!
Sammy 790 Posted June 5, 2017 Author Posted June 5, 2017 (edited) Que paso? En Ingles por favor.. Edited June 5, 2017 by Sammy
carloscabral 0 Posted June 5, 2017 Posted June 5, 2017 USE ONLY MOVIES ON .MP4 DO NOT USE .MKV, IN .MP4 THE SOFTWARE DOES NOT CONVERSION ALREADY IN MKV OPEN IF SEVERAL PROCESSES TO CONVERT THE MEDIA SO WEAKING THE SYSTEM
Sammy 790 Posted June 5, 2017 Author Posted June 5, 2017 While I understand this, nothing was in process of being converted from mkv to mp4 so I'm not sure why the utilization was so high. At any rate it has dropped to near zero now so all is well. As most all my playback is done on my 60" 1080p23 Plasma with lossless audio, MP4 as a storage container is not desirable and even then the bit rate needs to be downconverted anyhow for playback over the internet because my up is only about 7mbps and reliably 4mbps so I have Emby throttled at 1.5mbps.
