PremiumRed 69 Posted May 24, 2017 Posted May 24, 2017 Hi, I rebooted my server, now Emby starts but nothing seems to load. It asks me for my password, I enter it and the circle just keeps spinning as it was loading.. MONO did update to version 5.0 a few days ago, I don't know if that will affect it and I did downgrade from BETA to stable.... It has been perfect. Library scans finished before in 1 hours.... But this morning I left it all day and it was stuck on 27.0% so I cancelled scan and rebooted. Any ideas? Thanks in advance
PremiumRed 69 Posted May 24, 2017 Author Posted May 24, 2017 (edited) UPDATE: I just renamed Library.db files incase the DB was corrupted but it stil has the same issue with these files renames so its not a library.db issue Edited May 24, 2017 by PremiumRed
Luke 42245 Posted May 24, 2017 Posted May 24, 2017 I would get back on the beta. I did downgrade from BETA to stable We don't recommend switching between beta and stable - especially this time around because there are database differences between the two. In other words, the newer beta is making changes that the older stable will not understand.
PremiumRed 69 Posted May 24, 2017 Author Posted May 24, 2017 Okay, so should I upgrade again to BETA? I downgraded because I was recommended not to use BETA for live server
Luke 42245 Posted May 24, 2017 Posted May 24, 2017 Okay, so should I upgrade again to BETA? I downgraded because I was recommended not to use BETA for live server Ok, sorry about that. Yes, this is good advice, however you should make your decision at the time of installation, as opposed to switching the same installation back and forth. Yes I would suggest going back to beta. If you want to use stable instead, then do that on a fresh new installation.
PremiumRed 69 Posted May 24, 2017 Author Posted May 24, 2017 (edited) I have upgraded again but I have the same issue: I sent in PM login details Edited May 24, 2017 by PremiumRed
Luke 42245 Posted May 24, 2017 Posted May 24, 2017 What exactly is the issue? it looks like you just need to login and then you will be fine.
PremiumRed 69 Posted May 24, 2017 Author Posted May 24, 2017 (edited) I have logged in 5-6 times and still same issue I login and nothing loads... I can't even get to MANAGE SERVER to page I sent you details in private message As you see on screenshot, the menu bar at the left is blank Edited May 24, 2017 by PremiumRed
PremiumRed 69 Posted May 24, 2017 Author Posted May 24, 2017 okay I renamed user.db and then restarted emby server then I renamed it back to user.db Now I can login but I have lost all library data
Luke 42245 Posted May 25, 2017 Posted May 25, 2017 Ok, I would just set the library back up. This is obviously unfortunate, but it is probably due to the switching back and forth between release channels. We are going to add guidance about that to the download page of our website, and/or even potentially make it not possible to do that.
