PremiumRed 69 Posted May 23, 2017 Posted May 23, 2017 Hi, Version 3.2.17.6 beta Ubuntu 14.04 Since the last 4 days I cannot play any new recordings. I can play all previous recordings perfectly, but any new recordings will not play. Thanks
Luke 42245 Posted May 23, 2017 Posted May 23, 2017 A couple things - please provide the information requested in how to report a media playback issue. Second - if you're going to run beta it is important that you stay up to date with the latest, and your build is several behind now. Thanks !
PremiumRed 69 Posted May 23, 2017 Author Posted May 23, 2017 (edited) First - The recording doesn't record and log is too big Second - I can't update and stay up to date as your build server is not good and it says I am on latest version as I have reported 200 times aswell as other clients. I asked how to manually update as I like to stay up to date and you told me to wait for the build server to go back to normal bud Edited May 23, 2017 by PremiumRed
Luke 42245 Posted May 24, 2017 Posted May 24, 2017 Sorry to hear that. The beta repos are all up to date, just fyi. Thanks !
Sven 136 Posted May 24, 2017 Posted May 24, 2017 What's the reason that you are running the beta's? It's maybe a better idea to run the stable versions....
PremiumRed 69 Posted May 24, 2017 Author Posted May 24, 2017 Hi, I downgraded to stable and upgraded again to BETA and it is still the version: 3.2.17.6 I run BETA's as I like to test and report If no one ran betas, you developers wouldn't find the bugs as quick no? Thanks
Sven 136 Posted May 24, 2017 Posted May 24, 2017 Yes indeed. But it should be better to run the stable version in your live environment. And separate on another machine the beta version to test everything. So that you still can use your live environment for your daily stuff. So you are not blocked to do anything. Not everything is always solved in a couple hours...
Luke 42245 Posted May 24, 2017 Posted May 24, 2017 According to our build service the latest is available, 3.2.17.11: https://build.opensuse.org/package/live_build_log/home:emby/emby-server-beta/xUbuntu_14.04/x86_64
