Defeli 0 Posted May 23, 2017 Posted May 23, 2017 Dear All I know that this is a well trodden path but I would like to ask some advice on this one. I've got Emby Android installed on four devices. Google Pixel C Huawei P9 Huawei P10 Plus Huawei Media Pad 8 All the various settings are identical in all the devices and the permissions are the same. The Google, P9 and P10 all work perfectly and find the Chromecast and play seamlessly. The Media Pad simply does not find the Chromecast. I've checked everything I can think of but has anyone got any other ideas that I could try? The server OS is up-to-date etc. Any help with this would be very much appreciated. Defeli
HaraldBluetooth 22 Posted May 23, 2017 Posted May 23, 2017 (edited) Are all 4 devices on the same WIFI. If your router have 2.4GHz and 5GHz network, this could be the issue. Chromecast and device have to be on the same network..... Edited May 23, 2017 by HaraldBluetooth
Defeli 0 Posted May 23, 2017 Author Posted May 23, 2017 I've checked all of that and everything is running on the 2.4GHz WiFi. It's definitely a bit odd.
Luke 42243 Posted May 23, 2017 Posted May 23, 2017 It also depends on Google play services being installed and functioning properly.
Defeli 0 Posted May 23, 2017 Author Posted May 23, 2017 I've compared the version of Google Play Services in the Huawei devices and they are all up-to-date and working. I don't believe that I've missed any settings. It is really weird. The thing that makes it even odder is that Plex works fine on the tablet whereas Emby does not. I'll keep pursuing this as I'm really please with what Emby offers on all the other mobiles.
