Busta Uppa 0 Posted May 22, 2017 Posted May 22, 2017 (edited) Under Library Nfo settings I have "Copy extrafanart into extrathumbs" selected. I'm noticing that when I load up an artist in the library, it tends to download all images into extrathumbs, but only some into extrafanart. I thought it might be an issue with the "minimum backdrop download width" setting, but I tried changing that to zero and still got the same behavior - all images download into extrathumbs, only some download to extrafanart. Any idea what my issue might be here? EDIT: I disabled and the re-enabled copying into extrathumbs... behavior seems normal now! All images downloading into both folders. So I think I'm good here now! Edited May 22, 2017 by Busta Uppa
Luke 42201 Posted May 22, 2017 Posted May 22, 2017 Probably just some kind of sporadic I/O failure. If it happens again then please provide the server log from when it happens. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
