Embycon direct paths not working
Hi, so I decided to try out the embycon addon last night all in all looks and works great, except the username and password that is inputted into the config does not get used when you try and play something via direct paths. when looking at the log it just has smb://username:password@@MediaShare which I assume is the default you have in the Addon.
Regards
Scalda
I have the info log enabled and that is what it gives me as a output when I play something
Guest
