AmericanMike 18 Posted May 24, 2017 Author Posted May 24, 2017 Hi. Can you do this again but wait a little longer (like at least 60 seconds) before sending the log from the app? Also, post the server log from the same session. Thanks. Your log above never returned from the initial call to get information on the stream. sure I can do that. Just to be clear I'm sending good data do you want me restarting the server before I do this test or does it matter? Also do you want me to open a recorded file first to show that works then open a Live TV session or is that using different logic and not relevant?
AmericanMike 18 Posted May 24, 2017 Author Posted May 24, 2017 (edited) I had a few minutes so I thought I would run a test. All I did was restart the server, check that the Live TV functioned through Blue Neon Light, then launched the new application is the same erroneous result. I let it try to connect and display for at least 3 minutes. I then submitted the logs from the application with should be around 10:15am EDT. Server log and new ffmpeg logs attached. I didn't do any other testing such as playing recorded files because I didn't want to pollute the logs if not needed. thanks again for your help. I really miss watching my evening news!! server-63631217365.txt ffmpeg-transcode-5eed4dc5-7035-4451-900b-01e53ef06293.txt ffmpeg-transcode-629aa566-603e-492d-885e-3366ce7b82bf.txt Edited May 24, 2017 by AmericanMike
ebr 16335 Posted May 24, 2017 Posted May 24, 2017 Did you have two devices streaming simultaneously during that test? One at IP .22 and one at .18?
AmericanMike 18 Posted May 24, 2017 Author Posted May 24, 2017 Did you have two devices streaming simultaneously during that test? One at IP .22 and one at .18? .18 is my server and .22 is the Roku 3. I was connected to the server from my PC to watch the device connections which is also the same machine as the server (.18) thanks.
Luke 42242 Posted May 24, 2017 Posted May 24, 2017 For comparison purposes it might also be helpful to install the old app via the zip installation and see if that exhibits the same problem: https://emby.media/community/index.php?/topic/8001-emby-for-roku-channel/ Thanks.
ebr 16335 Posted May 24, 2017 Posted May 24, 2017 For comparison purposes it might also be helpful to install the old app via the zip installation and see if that exhibits the same problem: https://emby.media/community/index.php?/topic/8001-emby-for-roku-channel/ Thanks. I don't think it will since he said it works with BN.
ebr 16335 Posted May 24, 2017 Posted May 24, 2017 .18 is my server and .22 is the Roku 3. I was connected to the server from my PC to watch the device connections which is also the same machine as the server (.18) thanks. Can you set me up either as a Connect user or PM me credentials to attach my Roku to your server and see if I can reproduce under the debugger?
AmericanMike 18 Posted May 24, 2017 Author Posted May 24, 2017 Do you ever see the Roku video progress bar? negative. Just the revolving as per the pictures I posted.
AmericanMike 18 Posted May 24, 2017 Author Posted May 24, 2017 I don't think it will since he said it works with BN. and it worked daily with the older version before the update.
AmericanMike 18 Posted May 24, 2017 Author Posted May 24, 2017 Can you set me up either as a Connect user or PM me credentials to attach my Roku to your server and see if I can reproduce under the debugger? just sent you a message.
ebr 16335 Posted May 24, 2017 Posted May 24, 2017 Okay, if you will, please test with the beta channel. Thanks.
AmericanMike 18 Posted May 24, 2017 Author Posted May 24, 2017 Okay, if you will, please test with the beta channel. Thanks. beta works from my Roku 2. .24 didn't work before. Will test on my Roku 3 in about an hour. Thanks!!!
ebr 16335 Posted May 24, 2017 Posted May 24, 2017 beta works from my Roku 2. .24 didn't work before. Will test on my Roku 3 in about an hour. Thanks!!! Thanks for confirming.
Solution AmericanMike 18 Posted May 24, 2017 Author Solution Posted May 24, 2017 Thanks for confirming. Just confirmed that Live TV works on my Roku 3 now as well with the Emby Beta app. One thing I noticed that the icon on Roku 3 says beta, and Roku 2 did not. Not important, just an FYI. Great job finding the issue. Thanks. 1
