appie 0 Posted May 19, 2017 Posted May 19, 2017 I'm having problems with my Emby Server 3.2.16.0 installation on my Synology DS712+ running DSM 6.1.1-15101 Update 2. Somehow, all my scheduled IPTV recordings end up being about 1-2 minutes in length. I've tried disabling transcoding, but still the huge .ts files are about 500MB and 1-2 mins in length. It happens across shows, for all scheduled recordings and I can't seem to figure out what I'm doing wrong. Appreciate your advise and hope to resolve this soonest as my entire purpose for getting Emby Premiere was to enable scheduled recording for my favourite shows!
Luke 42240 Posted May 19, 2017 Posted May 19, 2017 Hi there @@appie, we're very sorry to hear about this. Can you please discuss a specific example and accompany that with the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ thanks !
appie 0 Posted May 20, 2017 Author Posted May 20, 2017 (edited) Ok, just did the following: Record 3:15-3:30pm: Dennis the Menace and Gnasher on Channel 1308 Settings: - convert into a streamable format: Enabled - If possible start # mins earlier: 1 - If possible stop # mins later: 5 After recording, the length of the video is only 2 minutes. Please find the attached server log for your reference (I've removed my IPTV provider details) Log.txt Edited May 20, 2017 by appie
appie 0 Posted May 20, 2017 Author Posted May 20, 2017 I imagine this is where it does the recording bit: 2017-05-20 15:14:00.0002 Info App: Recording timer fired. 2017-05-20 15:14:00.0308 Info App: Streaming Channel m3u_844a972f5596a9412b9774401b43a134946cb7383f2952a4927eb1e087b56980 2017-05-20 15:14:00.0323 Info App: Returning mediasource streamId 6922946e01814bd0b7c6d56d62ec0d632d88cdfc318fe37a8d35cec434f0d768, mediaSource.Id f55c25128fc840b4a08bc9047740da4c_2d88cdfc318fe37a8d35cec434f0d768, mediaSource.LiveStreamId 2017-05-20 15:14:00.0327 Info App: Beginning recording. Will record for 20.99945375 minutes. 2017-05-20 15:14:00.0327 Info App: Writing file to path: /volume1/Recordings/Dennis the Menace and Gnasher/Dennis the Menace and Gnasher 2017-05-20-1.mkv 2017-05-20 15:14:00.0327 Info App: Opening recording stream from tuner provider 2017-05-20 15:14:00.0327 Info App: /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -async 1 -vsync -1 -analyzeduration 5000000 -i "http://stream.iptvprovider.com:25461/live/username/password/1308.ts"-t 00:20:59.967 -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "yadif=0:-1:0" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 25000000 -maxrate 25000000 -bufsize (25000000*2) -vsync -1 -profile:v high -level 41 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ab 320000 -sn -y "/volume1/Recordings/Dennis the Menace and Gnasher/Dennis the Menace and Gnasher 2017-05-20-1.mkv" 2017-05-20 15:14:00.7038 Info App: ffmpeg recording process started for /volume1/Recordings/Dennis the Menace and Gnasher/Dennis the Menace and Gnasher 2017-05-20-1.mkv 2017-05-20 15:15:00.0541 Info TaskManager: IntervalTrigger fired for task: Refresh Channels 2017-05-20 15:15:00.0541 Info TaskManager: Queueing task RefreshChannelsScheduledTask 2017-05-20 15:15:00.0541 Info TaskManager: Executing Refresh Channels 2017-05-20 15:15:00.1564 Info TaskManager: Refresh Channels Completed after 0 minute(s) and 0 seconds 2017-05-20 15:15:00.2617 Info ServerManager: Sending web socket message ScheduledTaskEnded 2017-05-20 15:15:00.2617 Info TaskManager: ExecuteQueuedTasks 2017-05-20 15:15:00.6776 Info LibraryMonitor: Dennis the Menace and Gnasher (/volume1/Recordings/Dennis the Menace and Gnasher) will be refreshed. 2017-05-20 15:15:04.7281 Info TaskManager: IntervalTrigger fired for task: Cache file cleanup 2017-05-20 15:15:04.7508 Info TaskManager: Queueing task DeleteCacheFileTask 2017-05-20 15:15:04.7508 Info TaskManager: Executing Cache file cleanup 2017-05-20 15:15:08.2856 Info TaskManager: Cache file cleanup Completed after 0 minute(s) and 3 seconds 2017-05-20 15:15:08.3175 Info ServerManager: Sending web socket message ScheduledTaskEnded 2017-05-20 15:15:08.3178 Info TaskManager: ExecuteQueuedTasks From what it says above, it's supposed to be recording for 20.99 minutes. Why is it that its only recording for 2 minutes and then stops?
Luke 42240 Posted May 20, 2017 Posted May 20, 2017 Can you please also attach the recording conversion log? Thanks.
appie 0 Posted May 21, 2017 Author Posted May 21, 2017 (edited) Apologies! Didn't realise there was also a transcode log to upload. Please find the attached, although didn't see anything useful, besides the fact that it stopped after 2 minutes as if the file was done.. Transcode Log.txt Edited May 21, 2017 by appie
Luke 42240 Posted May 21, 2017 Posted May 21, 2017 Probably because it is a 2 minute stream that we're going to have to autoloop. We'll add that for the next release, thanks.
appie 0 Posted May 21, 2017 Author Posted May 21, 2017 Ah so what you're saying is that the IPTV provider creates a 2 minute stream and you'll have to keep looping it to get it to record 2 minutes at a time? Any idea when this new release would come out? I took a month Emby Premiere to specifically test out the recording feature. Is there a way to put my subscription on hold until the new version is out so I can test that? It kind of defeats the purpose if a month (or longer) from now the recording feature is updated and I wont be able to test it because my subscription expired. Appreciate your help and looking forward to trying out the updated version!
Luke 42240 Posted May 21, 2017 Posted May 21, 2017 No, but you can verify this by putting your stream url into a browser. The browser will just start downloading it. See if it stops after the same two minutes. If it doesn't, then the problem is something else entirely and I will need direct access so that I can test personally. Thanks.
