inzombyac 69 Posted May 18, 2017 Posted May 18, 2017 (edited) I went to check on my recordings this morning and noticed that several ongoing series are not in the schedule tab anymore. I looked in the guide and these channels are all missing guide data. I have two HDHomerun tuners configured with schedules direct data. I checked the channel mappings and these look correct. To troubleshoot, I deleted my tuners, my guide source and restarted the server. After restart, I added everything back and ran the update guide task. Everything came back except the missing channels (460, 512, etc.). While the guide is missing, the channels are getting the logos from Schedules Direct. I do not believe the guide data is bad because I have EPG123 set to give Windows Media Center the guide data and Media Center is fine. Log file attached. Please help, I don't want to lose my recordings. Here's a screen capture from the guide: Edited May 19, 2017 by inzombyac
Luke 42243 Posted May 18, 2017 Posted May 18, 2017 Try running a guide refresh and see if that fills them in, thanks.
inzombyac 69 Posted May 18, 2017 Author Posted May 18, 2017 Solved it by mapping the channels to an incorrect match, refreshing the guide and then remapping to the correct one again.
